WELL I CONNECTED MY 8GB SANDISK SANSA TO MY COMPUTER WITH AN USB CABLE TO CHARGE IT THEN IT WAS FULLY CHARGED AFTER I WAS SYNCING MUSIC INSIDE AND ALL OF A SUDDEN MY SANSA TURNS OFF AND I TRIED TO TURN IT ON BUT IT WONT I TOOK IT OFF THE USB AND IT DIDNT TURN ON THEN I CONNECTED IT BACK AND MY COMPUTER WONT READ IT
  • 4 Answers
Get ahold of sandisk sansa and there is a way to reset your mp3 player. always click on disconnect before removing it from your computer.
Posted on Mar 18, 2008
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
USB Port 2.0
USB Port location
Battery
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
Charging
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Try a USB plug o the back of the computer. These plugs have more power available.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. Check you screensaver and power settings.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Next try and reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Once it is back working, go to the SanDisk support site and get the updater program and update your firmware.
Jul 15, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Does not charge
Below are some things to check for when your Sansa player does not charge..
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Also try ports on the back of your computer, these ports have more available power. Some computers have limited power to charge up the device...
Jun 08, 2010 | SanDisk Sansa Fuse MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Battery
Latest firmware
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa View 8GB = would not connect
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Dec 26, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Sync issue
SanDisk Sansa View - Reset - Use the slide switch on the side and hold it tward the Mic hole for 10 sec. Then try to reload the drivers onto your computer, and use the disconnect button in the software, then re-connect the USB plug.
Dec 24, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
142 people viewed this question
 Grubhead
Grubhead
