Question about Sony VPL CS5 Multimedia Projector
Request for answer to solution sony vplcs5
My vplcs5 has (3) lines in blue baster when i turn on the projector. what is likely to be the problem.Can this repaired?
I´m having the same problem, the picture looks fine, just to much blue color!?!
Posted on Apr 17, 2008
My screen has a blue cast over everything. On a clear screen you see blue lines running up and down the viewing picture
I have the same problem with blue vertical lines all over the picture... did you find a solution?
Nov 16, 2013 | Sony VPL VW10HT Multimedia Projector
The screen is yellowish and blue colour poor of my sony projetor
Sounds like projector lamp-try reset, or take out and put back in. Otherwise check with on-line support at sony website
Aug 24, 2012 | Sony Office Equipment & Supplies
IN VGA input from the laptop, too much noise and shaky rolling black & Blue screen.
seems you burned one line actually A output i would say even input but you have to check line a
Apr 17, 2012 | Sony VPL-ES3 Multimedia Projector
I have a sony vpl vw60 projector. When it is turned on it shows only a blue screen. I do hear the DVD playing but only blue is shown on the screen. Not sure of the problem. I do have a replacement bulb...
Check out your output, they all show blue until you hook something up to them, make sure you have it hooked up right. write a post and let me know what you have hooked up to it.
Apr 23, 2011 | Sony BRAVIA SXRD VPL-VW60 LCD Projector
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Blue Haze on screen Sony cineza vpl-hs50 projector
Its your blue polarizer going bad. This happens over time due to the excessive heat generated in the projector. The main problem is that your projector has organic LCD panels that degrade over time and in turn degrades your blue polarizer. The same thing happened to my sanyo Z2. It took 5 years for it to show on my Sanyo because I only use the projector for sports and movies. not daily tv watching. In any case, it isnt worth it to spend the money ti fix it...jut put tat towrds a new projector. The latest crop of LCD projectors almost all use in-organic LCD panels that last much longer. Hope this helps.
Aug 03, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Projector SONY VPLCS!
I had the same problem with a Sony VPL CS1. It's not the mainboard, but the blue filter - cost to repair runs around $500 US.
Hope that helps.
Mar 21, 2008 | Sony VPL CS1 Multimedia Projector
Sony VPL CS5 Multimedia Projector Logo
98 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
