Question about Maytag Atlantis MAV6451 Top Load Washer
Hard to start dryer, control know loose/misaligned
It is very hard to start our dryer (maytag mde6657byw ).After setting the time with control dial, we pull the control cap out, which should start the dryer but it doesnt, after that we try to adjust the control cap upwards until it engages and dryer starts. Not sure what part should I order to fix this.
  • aznprsn Oct 05, 2008
    do you know the part number that i will need to fix this problem?
My dryer is the same, and will not start unless you do exactly as you said, "pull out and apply pressure upwards on the knob". I thought maybe it had something to do with the clothes wetness sensor. Now, I am not so sure!
Posted on Jul 14, 2008
    President:
  • Maytag Master
  • 2,651 Answers
Your saying that pulling the timer knob out, which normally starts dryer, does nothing. however if you pull out and apply pressure upwards on knob and touch nothing else, the dryer will start??? if the thats the case sounds like a short in the timer mechanism , youll need to replace the timer assy
Posted on Mar 18, 2008
Dryer model mde6657byw will not turn on . after I pull on the start knob and hold, it should turn but will not
How old is this modle? Lots of times even after a few years the timer will quit working,Those are timers in that knob and once they quit,,they need replaced and they are never a cheap date.
Mar 07, 2011 | Maytag Dryers
Dryer makes a ticking sound when the door is closed but wont start. If I put the dial on off, then the ticking goes away....help
the ticking noise is the timer, you dryer is not starting:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 25, 2011 | Maytag PYE2300AY Electric Dryer
Maytag MDE6657BYW RUNS BUT NO HEAT
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 14, 2010 | Maytag Dryers
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have to pull the knob on my dryer several times before it starts. It seems like its not catching?? Model # MDE6657BYW
You have an intermittent contact inside the timer. The fix would be to replace the timer (33002803). Be sure to unplug the dryer prior to service.
Apr 27, 2009 | Maytag MDE6657BY Electric Dryer
No dial on maytag dryer
heres what you do perm press is top right then delicates then airdry so start your dryer in the top right some where and when it stops mark it on face where it stoped and move it to start next cycle and repeat tell done
Feb 04, 2009 | Dryers
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Doesn't heat and dryer light no longer works
make sure you have power to BOTH legs of the 220v.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Maytag Atlantis MAV6451 Top Load Washer Logo
187 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
