Question about GE Advantium SCA1000H Convection / Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
The handle broke off at top screw. I have a replacement handle but cannot figure out how to disassemble the door to install new handle. I have an exploded diagram but this doesn't help. Can you? Thanks My handle of my advantium 120 - model # sca1000dww03 - broke off at the screws. I ordered the handle but dont have any instructions on how to change it out!!
    Guru:
  • 1,342 Answers
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Posted on Jun 01, 2008
2 Suggested Answers
  • 310 Answers
SOURCE: Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Help fixing a kitchenaid microwave oven/hood combo door handle
The door handles on most appliances, like outside cars & truck handles, are secured with screws from inside the door.
You will need to take the door completely apart to tighten the screws. This may be a very hard job, as it needs to be reassembled as well. God bless your efforts.
Oct 24, 2016 | KitchenAid Microwave Ovens
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Door handle replacement
your better to dismount the door first
you may need to remove the top case
{no power empty the glass out etc incase you need to tip it over}
sometimes you need to remove the whole top panel
either look for the expoded view for it also
and take lots of pictures first and as you go
go for it you can do it
its easy
i recon 8 screws max for the top of the case
and 4 screws for the top hinge
and then lift off the front
four screw to take off the actual front
and 2 screws for the handle
,,,, thats 14 screws in and out
Jun 04, 2015 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How-To Replace The Door Handle On A Kitchenaid Microwave Hood
behind door their is trim round the door use flat knife go between the trim will pop out and open 2 sc
Feb 01, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Need to replace door handle for Kitchenaid over-the-range microwave, Model: KHMS2050SSS - 0
You usually get better search results by leaving off any dashes or spaces in a model number.
Normally you have to separate the door panels (as shown in the photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful literature and exploded view diagrams with part numbers here and you can order parts from the Pros here.
May 21, 2013 | Microwave Ovens
The door handle on my microwave broke off at bottom of the door. The screws holding the handle on are not visible from the back of the door. How do I access the screws to replace the handle. GE Profile...
The back of the door will have a moulded surround that will be fixed with allen heads or small screws. Remove the inside cover of the door and you will see the holes for the handle.
Jul 03, 2010 | KitchenAid KBMS1454RSS Microwave Oven
Looking to replace the plastic piece on the vertical edge of the door (handle side) on my Kitchenaid Microwave/Hood combo khms145kss1. Is it possible to just replace this instead of purchasing the entire...
They don't show the entire door assembly as being available.
But you can replace the outer door frame (outer door panel)part number 8184319.
At $167.94, it's not cheap. But you can get it here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 29, 2009 | KitchenAid KHMS145KSS Microwave Oven
Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
Jun 09, 2008 | KitchenAid KHMS155L Microwave Oven
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
Chances are the door panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption of nearby electronic devices. You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 We have critical safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 06, 2007 | KitchenAid KHMS147 Microwave Oven
GE Advantium SCA1000H Convection / Microwave Oven Logo
743 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
