Brother MFC-440CN Error 50
I have a Brother MFC-440CN printer and I am getting the error 50 message. I have looked at the threads here http://www.fixya.com/support/t243260-err... so that I can reinstall the encoder strip.
But the 440 seems to have a different cover arrangement so even after removing the screws to 'lift off' the top cover, it still doesn't want to budge. It looks like the whole cover wraps around the printer.
Any help appreciated.
Chickenman
  • 797 Answers
The cover on the 440CN is tough to get off. I have removed many. I will tell you that the cable from the scan (black mylar [plastic]) is fragile. I destroyed one of the printers by killing the connector end of the cable. That being said, on the 440 you have to remove the push button panel before the cover. There are 3 screws in the back. The cover then snaps off but feels like you are breaking it and it will snap as it comes off. I did not break this part on any of the printers so.... you should not worry too much. After that there are clips on the front that keep the top cover on. You must release these with a screw driver. You can insert the screw driver and twist. While twisting apply some upward pressure and it will release. You also have to remove a number of connectors, ground wire to get it apart.
Posted on Jul 06, 2010
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
Error message "Unable to Change 51"
Unplug the unit, wait a few minutes and then plug it back in. It should cycle through and start back up for you.
May 14, 2010 | Brother MultiFunction Center MFC-440CN...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
My Brother MFC 440CN will not print
printer 440cn does not print. you call the printing option and the printer icon star jumping for a while then stop.I then open the printer queue and it is empty. I am running mac OS 10.58 in my Imac
Jun 20, 2009 | Brother MFC-440CN InkJet Printer
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to print 50
simple driver configuration problem linux is (the Cups printing system) is pretty universal just get your settings right or even cr even surrogate settings it should work
Nov 27, 2008 | Brother MFC-440CN InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Error message 50
Confirm Success on a 440CN
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
All Cured. Hopefully!
Nov 03, 2007 | Brother MultiFunction Center MFC-440CN...
Computers & Internet Logo
1,785 people viewed this question
Alun Cox
David Payne
David Payne
