Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer stopped working??
I have a Maytag stacked washer-dryer, the dryer works fine but the washer has stopped working. Won't seem to start a wash cycle, fill with water, but if you skip to spin cyle it spins fne. Checked water supply still on ok.
Any help appreciated?
Thanks in advance,
Angela
  • 2 more comments
  • aimeew Mar 27, 2008
    I have the exact same problem... any help? I had a load soaking in the tub, and when I closed the lid to have the cycle continue, it would not continue to rinse, etc.
    If I turn the dial to "spin" it will spin, but it will not start a new cycle.
  • jcserlo Apr 29, 2008
    We're having the same problem with the washer's spin cycle the only thing working. Were the thermal fuses the ones you changed out? (Mine tested fine.) If they're not the thermal ones, then where should I look for the other fuses? And where is the pressure switch?
    Thanks for your help.
  • Anonymous Mar 12, 2014
    ultima washer dryer
  • Anonymous Mar 16, 2014
    The washer skip to fill and wash
Just to follow up, it was the fuse that caused my problem. Hope this helps someone else!
Posted on Mar 31, 2008
    President:
  • 1,314 Answers
Change the pressure switch its the switch that you select the water level with
Posted on Mar 18, 2008
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
20 year old maytag stack, washer doesn't stop agitating
Your control board is bad. It must be replaced. It can not be repaired.
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer and dryer do not work
wires were shorting each other out that go into plug - once took apart saw the sparks so just cut and shortened wires and reconnected them to plug
Jan 27, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
Feb 27, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
312 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
