My computer & printer are not communicating properly. I also believe I have a birus and need a restore disk from the HP to reset my computer back to original settings from the factory.
    Sergeant:
    Champion:
  • 277 Answers
Run device manager and remove auknown software, then reboot your computer...
Posted on Mar 18, 2008
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
My computer is not communicating with my printer
Try reinstalling the printer driver.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Mar 27, 2013 | HP LaserJet 4730 MFP Printer
RESET TO FACTORY SETTINGS
What type of Laptop ? and operating system on it ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Dec 23, 2012 | Computers & Internet
Will not start
A brand name and model with operating system would be nice so someone could be precise. ?
Dec 10, 2012 | Computers & Internet
I have an HP computer in which windows services is
you won't need a disk all the backups are available in the back up option just hit restore or you can also opt to restore to the previous reset point. depending upon your os you will have to press either f8 key or f9 key while booting up and then select restore to earlier stored point.
Mar 06, 2010 | Computers & Internet
I AM UNABLE TO ADD MY PRINTER BACK ONTO MY COMPUTER AFTER REBOOTING THE COMP. i DO NOT HAVE MY START UP DISK AND I AM NOT COMP. SAVVY.
Did you reboot (restart) or did you do a restore? If you did a restart or turned off the computer and then turned it back on, I'd check for a bad cable. Many printers can be reset by unplugging the power and the USB cable (from both the computer and the printer) for a few minutes.
If you returned your computer to the original configuration or rolled back to a system restore point, then I can see losing your printer drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445441&lc=en&cc=th&dlc=en
will give you the drivers for most operating systems. Win7 has the drivers in the operating system.
If you use a Windows OS and your computer hasn't given you found new hardware dialog box, check if your cable is good and properly connected. (If it is attached through a print server, you may need to directly connect it to the computer to load the drivers.) Frequently, a bad USB cable or USB port can be identified by changing where you have the printer connected.
I hope this helps.
Dec 03, 2009 | HP Deskjet 5440 InkJet Photo Printer
How to make an HP Pavilion mx50 computer new like you just bought it?
Backup all your data & music & bookmarks & E-mail to an external disk-drive, or to DVD-writable disks.
Take the "System Restore" CD-ROMs that were shipped with your computer, and reinstall Windows.
If you have lost that set of CD-ROMs, telephone HP, and order a replacement set of "System Restore" CD-ROMs. Cost will be $20 for the disks, and $20 for courier-shipping.
Nov 14, 2009 | HP Pavilion MX50 15" CRT Monitor
My HP PSC printer won't print at all. It has new ink cartridges and prints off the test page no problem but the printer & computer aren't communicating
Go into Printers and Faxes check to see if the HP has a tick against it
If not right click on the printer and click on make default
Go to properties and hit Test Print
If that fails go back to printers and faxes and delete the HP
Add a Printer in the Printer & Faxes section
And when asked tell it you have a disk , put your driver disk in the PC and let it load
When it is happy re-boot and see it the printer is seen by XP on the start up.
If it does then let it finish and do the Test Print routine again
Jul 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
How to reset HP 1320N to factory default
Make sure you record your printer's settings before performing this procedure. Holding down the printer's Green print button briefly will print any configuration information.
a. Turn the printer power off
b. Press and "hold" the green "go" button whilst turning the printer on.
c. Continue to hold the go button for at least 5 seconds and until the amber
attention light turns on (triangle with ! in the middle), this should occur
before 15 seconds elapses.
d. Release the go button.
from http://www.pcreview.co.uk/forums/thread-2290821.php
The answer byteguy gave above would be the procedure to restore and HP Computer to factory defaults.
Feb 19, 2009 | HP LaserJet 1320 Printer
We are having trouble installing our new c6380 printer, we have tried to install it into our new hp computer three times via the usb port, with no success, our screen goes a foggy white, and we can not get...
You need to goto add remove programs and remove anything with c6380. then put the disk in again and reinstall. If that doesn't work remove again but this time after uninstall don't use the disk that came with the printer have the computer wizard search onlin for proper installation...
Nov 17, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
Alun Cox
David Payne
David Payne
