Question about Nextar MA566 MP3 Player
Help when i plug it in to the computer with the usb cable, it doesn't appear to be there at all. Only a blue sreen lights up, normaly the nextar would pop up on the screen and my comp would say hardware detected. Now nothing... please help me with this ty.
  • BMFG Apr 23, 2008
    Mine only says that it is installing the device then nothing pops up, (does not show the symbol on the bottom right corner of the computer.)
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 23, 2008
SOURCE:
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
When I turn on my 2 terabyte LaCie DD3US external hard drive, disk appears to rotate but I get a red light along with the blue, and clicking noises, and the drive's icon doesn't show on my iMac...
If the device doesn't show up in Mac System Profiler at all or as an unknown device:
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If possible, obtain another power cabling to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to another port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test. Try it on a friend's computer and see if it works fine.
If the tests above don't help, it's possible that the drive was either dropped while running, had a hard drive 'head crash' or the circuitry inside the drive is fried.
Hope this helps!
Jun 20, 2011 | Computers & Internet
Drive is not working. When you turn it on the blue light lights up but then goes off. The red light on the back stays on but the CPU does not recognize it. I have changed USB ports but it still doesn't...
please right click computer then Manager under storage, click Disk management. if you see you usb drive there, simply right click on it and format to exfat. fat32,or ntfs. if it doesn't show up, it pretty much shows that it needs an upgrade.
May 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I've installed program for by coby DP-151 photo keychain and followed the directions and disconnected the player from the computer. Upon reattaching the player to the usb cable I only get a solid blue...
I actually got tired of messing with this thing and tossed it. I've since found a photo viewer by Nextar with a built in CD rom and it automatically comes up when plugged in to the USB port. Works like a charm!
Nov 03, 2009 | Electronics - Others
PC does not recognize mp3 player
I pressed the volume control + button and held it down, then plugged in the USB cable
Oct 01, 2009 | Nextar MA566 MP3 Player
Nothing happens when I plug in my Nextar Mp3 player to the comp.
I PLUGGED IN MY MP3 PLAYER TO THE COMPUTER AND THE SCREEN ON MY MP3 PLAYER LIGHTS UP BUT the normal screen image for when you normally plug it into the computer ISN'T THERE AND I CAN'T ADD MUSIC ON MY MP3 PLAYER.
Jun 16, 2009 | Nextar MA7151B MP3 Player
IDK?
this means the driver isnt installed for the device.
first, try plugging it in, then goto my computer and look for 'removable device' that is where you will access the mp3's.
If all else fails, google 'nextar mp3 player driver'
good luck :D
Jul 03, 2008 | Nextar MA566 MP3 Player
Problems with usb device
Can you please provide me some information from that Blue screen
(That Blue screen is known as BSOD - Blue Screen Of Death - As on that screen you dont have any OK / Cancel Button and you dont have any other option other that Restarting your system manually when BSOD appears thats why it is known as Blue Screen of Death -
Anyways the important information from that error screen is located in the Second Paragraph + Last paragraph where some Hex codes are written
I want that information
Because most probably this is NOT a virus problem but it is a Hardware problem with your USB port)
Jun 02, 2008 | Computers & Internet
Nextar MA566
reformat your unit .... and download a new files of music
Feb 23, 2008 | Nextar MA933A MP3 Player
Nextar MA566 MP3 Player Logo
56 people viewed this question
Top Nextar Audio Players & Recorders Experts
Marvin
Marvin
Robert Graf
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
