Question about Samsung Televison & Video
WHEN I CHANGE MY SETTINGS ON MY LE46M87BD IT LASTS ABOUT 30 MINS THEN CHANGES TO DYNAMIC SETTING AGAIN HOW CAN I CHANGE THIS
  • COTTOZ Jul 02, 2008
    Thanks it worked any good settings for H.D
Its in shop settings. press button 1,....menu.......set up...plug and play....then start plug and ply..... will guide u through the rest ...then when you make changes it wont return to dynamic...hope this helps i had the same prob fixed now...
Posted on Jul 01, 2008
Samsung 55 inch led
Look in the owner manual--that likely is default setting and if a box used for signal that is possible also==
Apr 02, 2012 | Televison & Video
What are the best settings so that i can get the best picture from samsung plasma tv model PS50A457P1D?
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Mar 09, 2012 | Samsung PS50A457 50 in. Plasma TV
The TV will, on t's own, will go to the DYNAMIC (Fixed) setting every 30 mins. or so and I have to go to the settings I like. Then it will go back over and over again.
hello,
Dynamic (Fixed) setting every 30 mins. Then it will go back over and over again because of store mode has selected. To remove or set to home mode you can enter initial setup. Follow the instructions from TV set . Or enter TV location from menu than choose home.
Good luck.
Apr 01, 2011 | Sharp LC46SB54U 46 in. LCD TV
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
Series 80 gas dryer. Turn on and flame only lasts few mins.
Intermittent contact inside one of the gas valve coils. Replace. Part number 279834.
You can order them at AP Wagner. Use coupon "New10" for 10% off
Oct 16, 2009 | Kenmore 75944 Gas Dryer
My Samsung LNT3253H LCD TV has suddenly started changing its own settings (e.g. picture mode keeps switching to ''dynamic'' and the ''light effect'' keeps setting itself to ''always on''). Any thoughts on...
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Sep 05, 2009 | Televison & Video
My Samsung32'' resets to default settings every 30 mins!
Hi reset the tv and put it in to home mode!!!!
Shop mod resets tv settings every 30 mins
Apr 13, 2009 | Samsung Televison & Video
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
102 people viewed this question
Henry  Thomas
Henry Thomas
