Question about Radio Shack Pro-82 Scanner
Whenever I push the orange fd/pd button it only searches through 32.00 to 46.00. Then when I push lockout it says FLO-FULL.
What does this mean and how do I search all the freqs. on fd/pd?? Thanks.
  • ckyrux Mar 18, 2008
    Radio Shack Pro-82 model. Does not search all freqs when I push orange fd/pd button. What's up with it???
    Problem Solver:
  • 12 Answers
Go to cityfreq.com and you should be able to find the frequencies for your area.
Posted on Feb 06, 2009
  • 28 Answers
IT will only search the FD/PD codes range under the orange buttons. What you need to do is get a copy of your local frequencies and program them into your scanner, after that hit search.
Posted on Mar 18, 2008
How do i reset the lockout
Push and hold the button for 60 seconds. It is in customer lockout because it was pressed more then 3 times.
Apr 25, 2014 | Honeywell R7184A1026 Electric Oil Primary...
2 Speed Flo-Master stuck in high speed after turning on and off the electric
Is your switch an "air switch" ... could be you have a leak in the hose that connects from the push button to the actuator that actually does the switching. Check it out.
Dec 12, 2012 | Pool & Spa
I am installing a 1592SP Power-Flo Matrix pump and I cannot seem to press the positioning button (it does not depress) to rotate the discharge port. I have taken off the strainer housing, but no matter...
I just went out and did mine. My button didn't depress at all at first. While trying to push the button in, jiggle the discharge both ways; the button will move in and the housing rotates very easily.
Gary
Aug 31, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Moniter message power button lockout
Power Button locked out means that the power button is locked.
  • If the power button is locked, press and hold the power button for 10 seconds to unlock the power button function.
  • If the power button is unlocked, press and hold the power button for 10 seconds to lock out the power button function.
Hope this helps.
Apr 12, 2011 | Computers & Internet
I have a hp 1530 flatscreen monitor when I push the menu button on the screen it blacks out...and says osd lockout...what does tht mean...I have to unplug it in order for it to come bck up
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
Dec 29, 2010 | HP Televison & Video
The power button on my HP monitor keeps getting a message saying "Power button lockout" and the monitor will not turn off whenever i push the power button it just goes to sleep and i have to unplug it and...
Hold down the power button on your monitor, with the power on, for approx. 25-30 seconds and the monitor will shut down for good. When you will start it again, wait at least an hour, the message will be gone and the monitor will work as intended.
Jun 23, 2010 | Computers & Internet
How do you program a bearcat bc55xlrt scanner with a code?
There are no codes, only frequencies. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
To program your BC55XLT:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
You will want to lock out constant "broadcast" services such as NOAA or airport weather. Pressing Lockout will toggle the feature on and off.
Select a channel to program. Use the keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Jan 12, 2010 | Radio Communications
How do i program my BC 55xlt uniden scanner?
To program:
Turn on radio.
Pressing Lockout will toggle the status.
To program:
Select channel. Use keypad to enter frequency. Use "E" for Enter
decimal point.
Dec 04, 2009 | Uniden Radio Communications
Phoenix Gold PD-2999D Car DVD... Problem:
I bought a Universal Miniature AV Remote, then just started stepping thru the devices and codes. I got lucky and found it
To eject - push the Orange button, top Right.
Mar 12, 2008 | Phoenix Gold PD-2999D Car DVD Player
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Radio Shack Pro-82 Scanner Logo
175 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
