Question about Kenmore Elite 45986 Front Load Washer
Stuck in cycle
The washer is currently in its wash cycle, I was able to pause it and unlock the door to add another item. I closed the door and try to get it to continue and nothing will happen. I tried to pause/cancel nothing happens. It just keeps blinking its like its stuck. I have wet soapy clothes and I don't know what to do
    President:
  • Kenmore Master
  • 2,651 Answers
Unplug the unit. wait 30 secs. and repluge, youll have to restart cycle. but should work DO NOT add more soap
Posted on Mar 18, 2008
SOURCE:
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not restart cycle after a brief pause to add an item.
inspect the door latch assembly . you should see a plunger or switch that goes in and out as door shuts also should be a plastic stem that is mounted on the door that slides in and out of the latch assembly on the door
Aug 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stuck Mid-Cycle, Wet Clothes!!
unplug the machine for 15 minutes then try again
Jun 09, 2009 | Whirlpool GHW9150 Duet Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
419 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
