Question about HP PSC 2110 All-In-One InkJet Printer
Glass dusty inside
Need to clean the inside of the glass
    Sergeant:
    Champion:
  • 210 Answers
u can clean the glass using a lint free cloth. not necessary to have little moisture in it.
thanks and regards
agnel
Posted on Mar 18, 2008
SOURCE:
The scanner glass inside is cloudy
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
Mar 12, 2014 | Epson Perfection 1650 Photo Flatbed...
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
I have a ricoh 2232c. Do you know how I can clean
In order to clean the optics, you have to remove the two optic covers (one over the **** glass on the left and one on the rear side of the main platen glass). Each cover should have 2 or 3 screws.
Clean the **** glass and platen glass with alcohol and a lint-free rag (both sides) and blow compressed air onto the mirrors, lamp, and reflector. It's a good idea to turn off the copier before doing this.
When reassembling, clean the white strip on the underside of the **** glass cover as well.
May 08, 2010 | Ricoh Aficio 2232C Color Copier
How do i remove the glass from my built in moffat oven door as the inside of the inner glass is very dusty,there are no screwws or nuts to undo it or do you know a way of grtting into it to clean it
LOOK FOR VENTS AT TOP OF DOOR SPRAY IN OVEN CLEANER AND LEAVE FOR 20 MIN THEN SPRAY WITH WATER AND TURN OVEN ON TO HOT TO DRY DOOR.
Oct 18, 2009 | Ovens
It wont read the disc it says disc error on any video
clean the eye. look inside near the cd spindle and there will be this glass looking eye. Hopefully it's dusty..pure alcohol and very lite swabbing.
Mar 07, 2009 | Zenith ZRY-316 Video Recorder
The inside of the scanner
you'll need a full service manual, of course...look under manuals service for lexmark online..
Apr 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
HP PSC 2110 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
