Question about Visonik V2000T Car Audio Amplifier
Intallation of amp
Want to install amp using a 12v outlet in car, how do it do this?
    Sergeant:
  • 300 Answers
Don't! The amp will draw many more amps than what the 12V outlet (like a cigarette lighter) can handle. Most amps are wired directly to the battery (for the +12V) with a 30A or higher fuse (reference the owner's manual)
Posted on Mar 18, 2008
2014 nissan murano 12v power outlet at Center console and Cargo Area not working.
The fuse for the console outlets is a 20 amp fuse #33 in the fuse block. There is a relay involved and a 10 amp fuse for the control side of this relay. It, the fuse, is #19 in the fuse block. Check both fuses as either can make the circuit not function.
Jul 31, 2015 | Nissan Cars & Trucks
12v outlet
Yes, you will have to remove console and trim cover to find it. Install lighter back in console first than connect wires back up and re-install console.
Jun 30, 2014 | 2008 Dodge Grand Caravan
Add 12 volt outlet switched by ignition
maybe try getting your 12v feed from the radio power, this should be connected to the ignition switch and will run when the key is turned to accessory or the ignition is turned on
Dec 13, 2013 | 2005 Pontiac Montana SV6
I want fit 12v power outlet to my yamaha xmax 250 apparently its pre wired where do i find it
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
12v power outlet installation Horizons Unlimited The HUBB
How to install 12v power outlet to Motorcycle Cigarette lighter Tutorial...
Yamaha YP125R Service Manual
OEM parts for Yamaha
YAMAHA XMAX YP250R Owner Manual
Aug 05, 2013 | 2008 Yamaha XMax 250
2004 Chevrolet Aveo hatchback - lighter/12v outlet fuse blows
it sound to me like the lighter plug itself is loose and when you released the parking brake wiggled the plug enough to short out and blow the fuse . check to see if the plug is loose .
Apr 20, 2013 | 2004 Chevrolet Aveo
2005 ford f150 looking for fuse to the 12v outlet on the dash
Go to this FREE Ford website to view or download the owners manual to see the fuse block diagram for this vehicle on page 168. (if you don't have yours)
The front 12volt outlet/cig is position 32, 20 amp fuse
The rear 12volt outlet is position 40, 20 amp fuse
https://www.fleet.ford.com/maintenance/owners_manuals/results.asp
Oct 03, 2010 | 2005 Ford F-150
Fan blew 12v car fuse
You probably burnrd out the wiring into the lighter or, you burned the contacts in the lighter socket. You can not use an AC fan in a car. A car is DC.
Jul 09, 2009 | Radio Shack 120VAC 4" Fan
2008/09 Camry 12V Outlet Fuse Rating?
It will go to 30.In one sense you dictate up to 30 as it depends what the items rated amps are.The things you plug in are what you need to check
Oct 18, 2008 | 2008 Toyota Camry
12V outlet
Good Day,
There is no "easy" way to do that. However you can pull the factory wires from behind the outlet and re-wire it directly to the battery or constant hot source. If you do this be sure to add a 15 or 20 amp inline fuse to the circuit.
Hope this help.
Sep 11, 2008 | 2006 Hyundai Tucson
Visonik V2000T Car Audio Amplifier Logo
85 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
