Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Splitting the case
How do we get the case open to check if the heater is clogged. we have been trying and it does not just pop off. seems like it will be easy to break.
  • randyjc Mar 18, 2008
    I have taken off the top of handle, layed the bottom part of handle down, can you tell me where exactly is the s catch. I'am looking all over this thing, thanks
    President:
  • 1,673 Answers
The heater is in the handle. Take out the 2 long screws and nuts, remove the handle. Then on the back, below the cord and hose warp, there are 2 more screws, then lay the handle down, you will see s catch. push it in and the handle pieces will come apart. Pull the 2 lines off of the heater,( remember which ones goes where)Use a nail or something small that you can push in the ports that the lines were hooked to and clean them out, try to blow thru to see if if is cleared out. Then re-asemble.
Posted on Mar 18, 2008
  • Lauren Junge
    Lauren Junge Mar 18, 2008
    Right in the middle at the top.
  • Lauren Junge
    Just pull where I marked.
A friend used my Bissell Proheat Clearview shampooer, and didn't wash out the shamppoo bottle nor turn the dial to water only after using. The flow assembly on the bottle was destroyed. I bought a new...
A similar concern has been addressed on this site. With your indulgence, pls click here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 12, 2008 | Bissell Vacuums
Water doesn't not come out for rug cleaning ...pushing the switch....no water...motor runs....
Check to see that there is no clog in the sprayers. Take the tank off and there are two red sprayers. pop them off with a screwdriver and use needle nose pliers to take the retainers off. The sprayers will pull off and use a paper clip to push through the opening in the back. I would run the machine with these off for a couple to make sure there are no more chunks of soap in the lines. To avoid this problem in the future dont turn on the heater.
Jan 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water will not spray out. we've check all the troubleshooting suggestions , still won't spray
This seams to be a common issue with Bissell cleaners. Personally I think it's great but I love taking things apart. So I'll be more then happy to explain how to completely dismantle your cleaner......or I can just tell you where to look for the problem with the sprayer.......
From your frown I take it you don't have the "I don't care if it's not broke I want to take it apart anyway gene".
Ok the sprayer repair it is...
The two most common causes of the lack of spray are a worn, stretched or broken belt or a clogged heater unit. Along with those there are a couple miscellaneous items you can check also.
Since the belt is easier start there. Remember that most Pro Heats have two belt. A cogged belt which turns the brushes and a flat belt for the pump. Since I'm not sure exactly which model you have this description may not be a perfect match. The belts are located on the operators left. Turn the machine over and you’ll see a red retainer with 2 screws. Remove the retainer to gain access to the pump and belts. While you’re there check the red pump pulley, it’s where the two belts are. If that pulley is broken or loose you’ll have to replace the whole pump, the pulley is not available separate.
Before you check the heater be sure to check the spray nozzles at the front most Pro Heats have one on each side and they are attached with small hose clips. Just pop them off and make sure they are clear of any clogs.
After the nozzles and again this will depend on your Pro Heat model. Make sure that the nozzle on the bottom of the reservoir is working properly. Just pushing it open from the underside will verify it's not plugged.
If the belt, pulley and nozzles are all ok then......are you sure you don't want to tear it apart?......A relaxing weekend at home with carpet shampooer parts strewn everywhere? fine but don't say I didn't offer.
At the very least you will need to remove the screws from the back of the handle to gain access to the heater core. Please be careful as they can retain heat a long time. Remove the tubing from the heater and also the heater cover. You’ll probably see sediment inside. Clean out any sediment you see and use a paper clip on the nipple connectors where the clear plastic tubing was attached to ensure they are not clogged. After reassembly, running some white vinegar through your machine may help to clean out any sediment left behind.
If you have reached this point you could have a bad pump. In which case you can buy a replacement pump for around $20,00.
If this is the case please respond back to me with your exact model # and I can get you to a web site for a replacement and possibly even diagrams.
I hope something here helps.
Nov 20, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Miele classic vacuum,wont run, tried pressing restart.Was working fine earlier in day. When cord retracting the 1200 watt setting light on top of vacuum came on for a split second.
Vacuums have a heat activated breaker in them. Is the action end hot? If you get a clog, the motor won't get the air blowing through it and it will overheat causing the breaker to blow. If this is the case, wait (sometimes a few hours) for it to cool while you check for clogs then try it again. Hope this helps!
Aug 08, 2009 | Miele Vacuums
HOW DO i CLEAN MAIN TUBE IN HANDLE CLOGED
You'll have to unpick or slide up the rubber rings on the back of the handle at the bottom where the rear of the bag is. Unclip the bag so that it moves freely, slide up the rubber rings and you'll find a series of pop locks. Push these in to take out the main dust spine pipe - also remove the power cord at the top of the handle to release the handle. In the middle of the spine there is one screw that bonds the top handle part to the spine, unscrew this so that you can split the two parts up and check for clogs. Also check the main dust channel that leads to the bag - it is notorious for clogging because of its relatively small dust channel.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Bissell Pro-heat 12
These are two different problems the first could be a clogged heater soap coagulates in the heater passages and clogs the flow of water to see if this is indeed the problem turn the unit on and try and spray water with the top trigger (floor nozzle) then try to spray at the hand nozzle if you get water at the hand nozzle but not the floor nozzle it is the heater. The hand nozzle water bypasses the heater. Also check the solution or soap tank if you pull it out and there is not red seal on the bottom it may be stuck in the machine and won't create a good seal check to see if it is still in the hole where the tank inserts. As for the unit not turning on that could be a number of issues cord,switch or just over heated. Visit www.stevessewandvac.com for any parts or questions about this machine or any other.
Jul 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a Bissell powersteamer proheat. The problem is that the unit will no longer spray water/cleaner out of the bottom of the unit.
Check to see if water will squirt out of the hose, if it does, then take the handle apart, the heater may be clogged. Once you get to the heater, take off the 2 water lines, dig out the clog, try to blow thru the heater to make sure it is open, then put back together. Otherwise it could be the belt, pump, seal not in place on the bottom of the tank or a clogged water line.
Mar 05, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Nov 23, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
46 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
