Question about Amana ACS3350AS Gas Kitchen Range
SMELLS LIKE SOMETHINGS BURNING AND OVEN IS OFF!
FURTHERMORE, IT KEEPS BEEPING GIVING US A CODE OF: F5
  • Anonymous Jun 06, 2008
    I am very annoyed, my oven keeps beeping and saying F5...can someone tell me what is wrong??
    President:
  • Amana Master
  • 2,651 Answers
F5 is a bad erc(electronic range control) repalce control
Posted on Mar 18, 2008
Whirlpool oven model rbd306pdb15 has f5 error code and lights are on. Will not heat. Changed door latch, no help.
if you changed the latch the only other things are a broken wire or a bad computer board,this machine has two boards the clock assy. part WPW10438751 and another board part WP8301848.if you go to repair clinic you can order both boards install them first wp8301848 and see if it works because this is the cheaper of the two boards but you can send back the board you don't need up to 365 days,unfortunately when the machine has more than one board it's hard to say what one is bad,i have removed the ribbons on some units and when you plug the ribbon back in it works,possible dirt in the connection or something like that,sometimes when you remove the board you can see a burn mark on it or it smells cooked,wish i could give you a better answer but f5 is a bad latch,broken wire or computer board,can you let me know what you find thanks so other people might be helped by what you find,and i'm sure you know to kill the power to the unit before you work on it always do this.
Nov 08, 2017 | Whirlpool Ovens
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
F5 code on Whirlpool gas stove
F5 Defective ERC Replace ERC
Aug 24, 2009 | Ovens
F5 code keeps beeping and wont stop
HI. the relay drive circuit has failed. If this fault code cannot be canceled, replace the oven control (also called clock or ERC).
Jun 19, 2009 | Ovens
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Apr 25, 2008 | Ovens
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
Amana ACS3350AS Gas Kitchen Range Logo
172 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
