Question about Maytag Performa PAV2200
Maytag dryer won't heat up
I have a maytag performa dryer. It was working fine and then it just stopped heating up. It turns and the timing works but it doesn't get hot. I've never worked on an appliance before, but I think it must not get a spark or something to ignite the gas. Is this something I can fix myself? It is a Maytag Performa, but I don't see PAV2200 anywhere. The model number on the door is PYGT244AWW.
  • 5 more comments
  • Anonymous May 10, 2008
    SAME EXACT Problem.
  • kmbousq Sep 04, 2008
    the dryer heat up and them stops heating
  • sntsmiss Sep 22, 2008
    I have the same thing. The dryer starts to get hot then quickly turns to air fluff. Will not stay hot.
  • mbravo29 Oct 20, 2008
    Is there an easy fix?
  • Anonymous Apr 27, 2009
    My Maytag Performa PYG 2200 AWW is not heating also. It happened in December along with the belt breaking. I had it repaired, but now it wont heat again just 4 months later. Now I am shopping for a new dryer. :(
  • bobo49285 May 11, 2010
    where is the anwser or solution to this problem located at?
  • alvelodaniel
    alvelodaniel Mar 15, 2013
    heating element $26 dollar fix lift open the top use a flat head to pry open you will see the heating element at the back also replace thermostat
I am having the exact same problem with this model as well just happened 4 days ago.
Posted on May 03, 2008
Dryer noise and no motor action
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Maytag PYE2300AY Electric Dryer
Maytag performa pav2200 dryer has stopped heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
tust
Jan 24, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
My maytag dryer won't heat up
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 17, 2009 | Maytag Performa PAV2200
Maytag performa dryer doesn't fully heat
A couple of suggestions. STOP, be sure the gas it turned off before disconnecting the line. Move it to an open area and check all venting. A good cleaning makes a huge difference. I believe your problem to be the heating coil is on it's way out, "works sometime". Write down the Make, Model, Seriel Number & Year of MFG...someone may ask for it..Check Your local appliance store for price & availablity Easy to replace on most model dryers.
When reattaching the gas line, be safe not to overtighten the coupler. A safe test for leaks is NOT a match... a drop or two of dishsoap around the fittings will bubble if it is not sealed. Good Luck
Jan 02, 2009 | Maytag Performa PAV3200
Dryer is not heating
If a washer is not heating the part responsible can be thermal fuse, heating element , control assembly, or a bad wiring.
All parts must be tested by a technician and eventually replaced.
You can get schematics and parts by entering the model number here.
See also the link below for more help, or to get parts:
There's no heat
Dec 12, 2008 | Maytag Performa PAV2200
Maytag performa gas dryer no longer produces heat.
needs a new timer switch sometimes cheaper to buy another dryer (used)
Dec 02, 2008 | Maytag Performa PAV2200
Washing Machines Logo
2,492 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
