Tv problems I have a rear projection RCA tv that won't turn on but instead makes a clicking soun like a bbq that trys to light just wondering what the problem could be
    Master:
  • 518 Answers
Sounds like the high voltage stages aren't firing up. Could be a number of things: Blown fuse, bad horiz output transistor, bad regulator IC, bad flyback transformer.
The reason this happens is because the high voltage also supplies the rest of the voltages needed to operate.
Geno
Posted on Mar 18, 2008
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" rear projection tv
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | RCA P52920BL 52" Rear Projection...
52 in RCA projection hdtv picture keeps going in and out has soun
If you can solder yes you can fix it your self Ck 3 capacitors cp110 cp114 cp150 --- If cp 150 is puffed up on top it is bad 2200uf 16v other 2 are 220uf 35v replace all3. also resolder all pinns on FBT flyback transfomer and make sure both ribbon connectors are in good.
Jul 20, 2009 | RCA HD52W151 52" Rear Projection HDTV
After turning on wont work for an hour or so
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
Please give is a good rating.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | RCA P60920BL 60" Rear Projection...
Power turns off immediately.
They are located on the center board mounted to aluminum heatsinks
Jan 19, 2009 | Philips 60PP9352 60" Rear Projection...
52" rear projection television
you need to rplace the flyback. very easy repair. you need flyback 259296 you can get a replacement flyback at the following link with free step by step installation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turning on tv
try resoldering the flyback, they are famous for bad solder connections as well as bad flybacks.
Jun 24, 2008 | RCA D52W19 52" Rear Projection Television
RCA P61927 61 in. Rear Projection Television
get a tv repairman out to make sure of the problem, it might be xomething simpler he can fix but it sounds like the convergence board is out
Jun 21, 2008 | RCA P61927 61" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Problem with TV
that model is famous for bad flyback and HV splitter
Mar 17, 2008 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
