Question about GE Energy Star WCVH6260F Front Load Washer
After 4 months, water pump went bad
This is total bulls-ht that after 4 months of light usage (2 people in household), this machine would go bad.
GE has lost all of my confidence.
  • 1,314 Answers
More than likely you have a foreign object jamming the water pump nickle dime quarter etc clean the pump out it should work fine if its 4 monthes old you can call for service but if its something jamming the pump its not coverd by warrenty
Posted on Mar 18, 2008
Which is the maximum duration of the calcium cleaning cycle
Hello Fellow Espresso Maker
We at Expressfix recommend you descale every 6 month depending on water quality and usage. We tell our clients every 6 month to prevent scale build up and proper operational status for normal usage(2-3 drinks daily). Poor water quality leads many future preventable service calls.
Sep 17, 2013 | Gaggia Titanium Espresso Machine
Not enough hot water ge smartwater water heater gas
1) Copy following links:
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
New Samsung Wasging Machine Model:- WD-J1255R/YNG not functioning
your drain pump seems to be obstructed. If water is still in the drum, no spinning will take place. Remove pump and check the impellar for obstruction and the 2 pipes connected to the pump. make sure they are clear by blowing into the 2 ends. If you are able to, it would help to test the pump before you put it back into the washing machine.
Jul 17, 2010 | Samsung Washing Machines
This is the 2nd B60 that appears to have a pump
I unplugged mine and it fixed the problem.
Jun 03, 2010 | Keurig B60 Coffee Maker
Low water pressure is diminished after replaced 2 filters in a month. plumber tested to see if water is fully flowing.
Does this mean that you are now having the right pressure? Since the filters are changed, water should
now flow. Is it all systems go?, that is assuming that
your pipelines are not clogged.
Nov 05, 2009 | General Electric GE SmartWater Household...
GE Hot Water heater about 2 months old - today no hot water -
Turn dial from vacation to higher setting liker warmer if not hotter if not already there. If this does not work let me know. Please rate. jj505
Mar 29, 2009 | General Electric GE SmartWater Household...
Washer keeps pausing
you may have something in your drain pump.
1) Remove the three screws in the bottom remove bottom panel.
2) Remove drain pump cover (have towels or pan to catch water that comes out)
3) Remove any debris from pump, check that the impeller is not damaged and can be moved freely.
4) reinstall drain pump cover and bottom panel
Let me know if it helps
Sep 07, 2008 | GE WBVH6240F Front Load Washer
Washer stops in middle of cycle,
Junk it! Cut you losses now. I had a Calypso for 6 years and went through 3 pumps, various circuit boards , a drive motor ,etc..... not to mention the down time of not having a washer in a 4 person household. We bought a Whirlpool Duet HT 9200. Clean , fresh laundry not all balled up anymore. Junk it. You'll thank me.
Nov 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Old GE Washer WNSR2100T8WW will not pump out water nor spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 12, 2007 | GE WJSR2070B Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
41 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
