Question about Hitachi 43UWX10B 43" Rear Projection Television
Red will not line up
The red lines on the grid will not line up. They are curved, the ones on the top curve up and the ones on the bottom curve down. We have replace the stk's. What could be the problem?
  • MICHAEL WALLACE
    MICHAEL WALLACE Apr 11, 2008
    my red will not lineup. it go'sdown on the right bottemside, and magicbuttonwon't.line itback in to place.how do i fix.?
Had the same problem a couple of years ago, it is a defect in the TV. Contact Hitachi it's a convergence issue they will do everything to tell you it's wear but that is not true. I made a big deal about it and finally after contacting many people and doing much research on the problem Hitachi agreed to paid for the part which costs $360.00 Cdn. However, they did not pay labour (only $65.00). Hope this helps.
Posted on Apr 16, 2008
    Genius:
  • 1,153 Answers
Return resistors need changing
Posted on Mar 18, 2008
SOURCE:
How to fix the color alinements
You need to replace the two STK-392-560 CHIPS THIS SET USES AND DO NOT RUN THE SET WITH CONVERGENCE BOWED or soon you will have other parts bad.
May 27, 2012 | Sony KP-57HW40 57" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Curved red lines on the screen and the picture is distorted
This is a convergence problem that can be either poor solder connections on the convergence ICs or defective ICs. If you can solder you can fix this yourself. Update this if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 23, 2009 | Samsung PCL545R 54" Rear Projection...
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Magic focus grid not straight.
i'm no expert by any means; but I wonder if it could be as simple as the reflective screening on the inside comming loose. I have a 65" and I took it apart to clean it. The reflective screening looked to me like it could be a weak point. Just a thought.
Jul 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Good Day y'all;
First of all if the lights are on, that's good, the red light,LED's, indicates that there is power to the power regulator IC. The green lights, LED's, indicate that the DC voltages are present for those particular circuits. ALL GOOD! If off bad!
If after replacing the IC's with the 150's and still have color shift and all resistors are within 2% tolerance and adjustments were made properly. The digital convergence board may be defective.
If the picture is bleeding that normally is a gassy CRT, picture tube, and the bleeding changes with the brightness levels. You may try to rejuv but that may short life the tube.
Good Luck, get back if you want more details, Big Irish.
Apr 21, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
