Question about Dishwashers
We have Kitchenaid dishwasher KUDS 24 SE and detergent is still inside after the wash process is over!!!We try diff.kinds of detergents!!!Please help.Machin is 10 yrs.old.
    New Friend:
  • 136 Answers
Use some vinegar in your wash cycle
Posted on Mar 18, 2008
SOURCE:
White residue on dishes and inside of dishwasher. 1 and 1/2 years old
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Jan 14, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Out dishes come ot with a film that looks like soap. It seems like it does not rense completely. Thanks,
Hi
Daniel
Aug 21, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Tablet will not dissolve
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water on the bottom at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 02, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
KitchenAid Dishwasher Rinse Aid Clogged w/ Detergent
have you tried distilled vinagar? this may work for you.
Jul 29, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Dirty dishes
On the quest to save water, dishwashers are very frequently overloaded. On the quest to save detergent, they often don't have enough detergent to wash the residues out of them. Try making your dishwasher run with a full load of detergent, no dishes and a nice amount of bleach in it. Do this once in a while and your dishwasher will eventually work much better. Do be careful about any chlorine fumes.
Mar 11, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Jan 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Milky liquid residue on washed dishes
This sounds like hard water spots.  Use Jet Dri or a similar product to reduce it. Use the recommended amount of detergent.
Nov 15, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Maytag 24 in. MDB9750AW Dishwasher
Dishwashers Logo
362 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
