Problem with TV
Hello I have a RCA rearprojection tv it's model no is P46730Wk and it just stoped working this morning it won't turn on and it is making a clicking sound like a bbq lighter that won't start
    Problem Solver:
REPLACED TRANSFORMER HV BLK STILL SHORTS OUT HOTRANSISTOR AT START UP
Posted on Apr 10, 2008
  • 8,617 Answers
That model is famous for bad flyback and HV splitter
Posted on Mar 18, 2008
SOURCE:
I can't get tv to change input so that my DVD
What is the brand and model of your TV? Usually, you just need to press the VIDEO button or VIDEO/TV repeatedly until you see your DVD on it. It depends on which port you connected your TV. Make sure that your DVD player is connected properly. If you are using RCA, make sure the yellow cable (video) is connected to the yellow port of your TV and your DVD player. And also make sure that your DVD player is turned ON. If it still won't work, try a different cable.
Oct 06, 2011 | Televison & Video
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
TV won't turn on
Hi There,
Try unplugging the TV and wait 5 minutes, plug it back in. Let me know what happens.
Mar 29, 2009 | RCA Televison & Video
Rca d52w20 52in. rearprojection tv monitor
Remove the back panel from the tv where the input jacks are located. You will see a red power wire. Just above that and to the right approx. 7" or so you will notice a [_] shaped metal shield surrounding a cgreen/gold capacitor. You may need to remove the plastic cover that is located directly above it about 6-7" in length to gain easy access. Run your finger over the top of the capacitor. If it is beveled rather than smooth you have found a definite solution to your problem. The part number located on the board is CP150 16v 2200uF capacitor. It will look like a tall cylinder. Good luck!!
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Projection TV will not turn on
What model Rca do you have? I can probaly point you in the right direction if you let me know the model number.
Jan 17, 2008 | Televison & Video
Rca p46730wk 46 tv
I have same set with same problem, no power. I just opened up the rear of the unit, where all of the circuitry is, and let loose a can of compressed air and cleaned off all of the caked on dust and dirt that had accumulated from the previous owner. And i mean let loose, make sure every surface you can see is spotless, and avoid blowing the dust up and ito the lenses, then I kept hitting the power button a few times, and it turned on and is working fine now.
I turned it on and off about ten times now and haven't had a problem.
Hope this helps.
Oct 28, 2007 | Televison & Video
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
257 people viewed this question
Top Televison & Video Experts
Ekse
