Question about Panasonic PT-53WX42 53" Rear Projection Television
Mines blinking 3 times and then pausing
Whats wrong with it and what should i do and how much do you think it will cost to fix it?
  • Panasonic Master
  • 8,617 Answers
3 blinks means convergence. The Ics cost about 10.00 each you will need to replace both of them. Also check the resistors that power the ics. They are located right next to the ics easy to spot theres about 7 of them all identical with no color bands on them like normal resistors have.
Posted on Mar 18, 2008
What is Code 33 on Onan Generator Model12.5 HDKCB11506B?
You may be reading the code wrong, Code 33 shows up as blink 3 pause blink 3. This means it has a lower level code fault. To access the real code. Press the stop button 3 times fast within 5 seconds and re-post what the code is please. It may blink pause then blink again, that is the lower fault code that will help diagnose the problem.
Feb 10, 2015 | Onan Generator, 4000W, Gasoline
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
TV comes on for 3-4 seconds and then turns off. The power light then blinks 3 times and then pauses, then 3 more blinks ans pauses.
3 blinks is short protection and 98% chance one of the resistors in the convergence circuit is gone.
I can tell you what to look for and if confirmed how to fix set. If the usual problem total parts cost on EBAY will be well under 25 dollars.
If one of the resistors is bad, I have step by step start to finish instructions I can provide for this repair, for most it is a do it yourself job.
If you have questions let me know.
Regards, SD TECH
Nov 03, 2010 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
I just replaced the bulb in my sony grand wega kf50we610 yesterday. today my tv turns on for less than a minute and shuts down. not sure how many lights blink? please help what can I do?
Look for the blink code when it shuts down--it will point you in the direction of what the problem is--for example if it blinks a sequence of 3 blinks and a pause and 3 blinks etc---it is an easy repair you can do and the parts cost is under 20 dollars--what is wrong will be indicated in a general way by the blink code--it is a error code.
SD TECH
Dec 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi WS55859 turns on for 3 sec. then turns off
Ic's went out again. Did you check all the bias resistors? Must always look the board over for cold solder joints also.
Oct 22, 2009 | Televison & Video
How can i stop airbag light from blinking while driving
Your airbag light blinking is telling you that something is wrong within the airbag system. The blinking is giving a code, it will blink x amount of times, then pause and again blink x amount of times. Example it blinks 3 times, then a pause, and then blinks 2 times, means the code is 32.
After you get the code you can find out what the problem is, and what exactly needs to be repaired. If you're not experienced with airbag systems, it is best to have it serviced by a professional.
I hope this helps you, and I wish you luck on your repair.
May 02, 2009 | 2004 Nissan Armada
Blue power light blinking 3 times
I am having the same problem, what was the solution to this problem? And how much did it cost to fix it?
Jun 21, 2008 | Hitachi P50T501 50 in. Plasma HDTV
Mom's tv
Okay check the self diagnosis feature, Hold the input and menu buttons in at the same time on the set, hold for 5 seconds see if the set blinks 1-2 blinks pauses then blinks 1-4 blinks. If so let me know the number of blinks. If not check the following items in the power supply for being open or shorted.
R9A02 R9A22 R9A23
Check Q9A51 Q9A22 also its diodes D9A31 and D9A32
Also check the 3 fues F9Doo, F9A01 and F9A06
Also check the solder on T9A20 and the flyback . Let me know what you find.
Feb 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 55hx70 projection tv problem
How many times does the light blink? It should blink a number of times, pause then blink the same amount then pause. Try to count the blinks then let me know. Also how long does it run before shutting down if any?
Jan 20, 2008 | Toshiba 55H70 55" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
