Question about Panasonic PT-53WX42 53" Rear Projection Television
Mine is blinking 3 times then pausing
What do i need to do about this?
  • Panasonic Master
  • 8,617 Answers
Convergence amp ics and possibly the resistors that power them under 30 dollars if you solder them in yourself.
Posted on Mar 18, 2008
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
May 07, 2014 | Electric Mobility Pronto M41 Power Chair...
Sony Flat
Goes from on to Standby by its self because of protection mode that activates for some internal problem. Do you see standby light blinking on tv front? What is model number of your tv? How many times standby light blinking after 3 seconds long pause? Let me know to find out possible cause of problem.
Jul 25, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The led light blinks 3 times then pauses then
Pressure switch error code, Check the air filter for blockage, check the vent pipes for blockage or water, make sure the condensate drains are working and that there is no water in the hose(s) that go to the pressure switch(s).
Jan 06, 2010 | Goodman GMS90703BXA Heater
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
I have a blinking red light with no picture
Blinking red light shows TV got some problem internally and need to be repaired.
Now important thing is how many times that red light blinking? There would be pause of 3 seconds in blinks so count pause to pause and let me know to find out possible cause of problem.
Is it Sony KDS-55A2000 model TV or any other model?
Sep 21, 2009 | Sony KDS55A2000 55" HDTV
Mines blinking 3 times and then pausing
3 blinks means convergence. The Ics cost about 10.00 each you will need to replace both of them. Also check the resistors that power the ics. They are located right next to the ics easy to spot theres about 7 of them all identical with no color bands on them like normal resistors have.
Mar 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
18 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
