Question about Elna Quilter's Dream 6003Q
Programing How do I program my sewing machine to take 3 stiches then stop?
    New Friend:
  • 136 Answers
Program-controlled sewing or embroidery machine comprising a stitch-forming device (2), an integrated microcomputer (4), at least one memory (16, 17) and at least one data interface (5), as well as a keyboard (12) and a display (11) for entering and monitoring or checking values for program control. To retrieve sewing or embroidery pattern data from a remote computer (mailbox) in a simple manner, the data interface (5) of the sewing or embroidery machine (1) is able to be connected directly to the mailbox (10) of a central computer (9) via a data transmission connection (7) via a corresponding modem (6), and the structural units which are necessary for communication with the mailbox (10), such as display (11), keyboard (12) and memory (16, 17) are disposed in the sewing or embroidery machine (1) itself, with the functional processes necessary for communication with the mailbox (10) being able to be controlled and monitored by the microcomputer (4) necessary for controlling the program of the sewing or embroidery machine. The invention further relates to a method of operating program-controlled sewing or embroidery machines.
Posted on Mar 18, 2008
Practising different stiches on my juki and I think ive programmed them in. so now when I choose a stich it does a couple then jumps to the next one and the next one and so on. how do I unprogramme
Sounds like you didn't effectively close/save one program before beginning a new program so the machine is running them all together in the series in which they were programmed.
Sep 30, 2017 | Juki Sewing Machines
Brother sewing machine model AS1430S not picking zig zag stich....on zig zag stich option it is only giving straight stich.....plz help
Try a brand new needle. If that doesn't work, then the machine may be slightly out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Brother Sewing Machines
My Nina JE1918 stopped sewing all stitches except straight.
it's possible that the part that sews the other stitches needs to be checked to see if it's worn or damaged.
Aug 28, 2013 | Bernina Sewing Machines
My stiches keep missing a stich
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
Aug 06, 2012 | Husqvarna Huskystar 215 Sewing Machine
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Machine will not sew forward without backstitching
You have selected the Stretch Stich (SS) mode on the stitch length regulator, just turn the knob around until you have a number 1 - 5 and that should be it.
The model number will be the last digits on the metal compliance plate with voltage etc.....looks like:
V / 1234 / 123454321 / 2016
www.bargainbox.com.au
This then would be a Model 2016
Nov 25, 2008 | Sewing Machines
Sewing machine not making stiches
At first, my machine was getting all tangled under the fabric and then would stop working because it was tangled in the bobbin area. Now the bobbin area is staying clear but there are no stiches being made. I have no idea what to do. melissashulga@yahoo.com
Sep 07, 2008 | Brother LS-2125 Mechanical Sewing Machine
Hole width
After putting on the buttonhole foot, you lower the foot, put in the size button you want into the button hole foot. Lower the button hole lever all the way (so machine does not blip) Then the machine automatically sets the length and width of the button hole...you can adjust the length and width manually by pushing the button on the top right hand part of the machine above the LED screen the top one is stich length the other is stich width....if you put the levers to the left it will be the smallest stich length or width...if to the right it will be the largest stich length or width the machine allows. But, really the machine automatically does this for you...so I don't see the need to do it.....but you can....BBill01
Jul 22, 2008 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
119 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
