Question about IBM NetVista PC Desktop
Screen does not light up
I have an old IBM NetVista. When I switched it on today the screen has remained black although I hear Windows start and I hear the fan running etc. Do those screens burn out? The screen and CPU are all one piece.
  • Anonymous Apr 26, 2008
    IBM netvista 21U start's up but screen stays black although everything is running ok .it does not show all the words and digits when windows is booting ,please help
  • salisbury1 May 17, 2008
    yes,i have the same problem.I would like to try both solutions.You need to be able to see whats on the screen,so you know what your doing.
Don't listen to this turkey. IBM has a security feature on their computers which you'll need to disable. Reset the BIOS and when you first start up the computer, press the F1 key to access the BIOS and disable the security chip.
Posted on Mar 18, 2008
    Guru:
  • 55 Answers
Hey u r in deep trouble u have messed up the o.s now u have to reload the o.s from a recovery c.d....
SOURCE:
IBM Netvista A30 8315-61U Windows startup Problem
IBM Netvista A30 8315-61U what does IBM have to do with DELL?
huh?
that is now Lenova , IBM sold PCs div, to Lenova long ago.
so ill move you to lenovo
my guess the post should read
old Pentium 4 PC from Lenovo per above
I can not install and OS
NO OS stated, windows sure... but...
NO version OS stated XP, vista,w7,8,8,1.w10
no media you are using to install it.
the cure is easy , re-Install windows fresh
all data and your apps will be gone, we backup first.
if that fails the HDD is bad, run HDD test.s
run crystaldiskinfo on it if smart param, C6 is wrong, the drive is toasted.
Mar 04, 2018 | Dell Dimension 4600 PC Desktop
Drivers for ibm netvesita 6790
Here is a link to the most common drivers for this machine. Scroll to the bottom of the page and click the driver name you need. This will take you to the download page.
http://www.driversforfree.com/omn_ofm_omd/ibm/netvista/6790/drivers.aspx
Sep 12, 2011 | IBM NetVista PC Desktop
I have a refurbished ibm netvista. when i turn it on, the cpu fan will start to spin for a few seconds, then i'll hear a weak beep, then the fan will stop spinning (power off), then the fan will...
Remove the hard drive and RAM. See what it does. It should go into BIOS and complain. If it doesn't you have a motherboard issue as it won't POST.
Dec 24, 2010 | IBM NetVista PC Desktop
I connect my IBM Netvista to electricity, the fan motor starts , but nothing on the scree.
Make sure all of your connections in the back are solid. If you still have problems post back with details (any beeps etc).
Jul 09, 2010 | IBM NetVista PC Desktop
I am trying to restore an old IBM 2194 Model 18A. It seems to do the test of RAM but the hard drive does not light up (it does start running) and ther is a black screen on the monitor but it does turn the...
If the BIOS battery is a coin size battery 20mm dia.- type CR2032 then the BIOS battery voltage should be 3 volts.
Replace it with a new battery and configure the BIOS with Date and Time etc.
Jan 28, 2010 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
Power switch pinout for the 02R4087 motherboard Hi guys I have an old IBM motherboard IBM 02R4087 Netvista Motherboard which appears to be from a Netvista model (NetVista 8182, 8305, 8306, 8309, 8313 ). I...
Progerssed the internet and got a FREE note Free response. Did not have to spend money on your pathetic permium system. Why should you charge for what others give for free?? Parasites
Jul 09, 2009 | IBM (02R4087) Motherboard
Unable to Acces BIOS on IBM Netvista 607931u w/ Phoenix ROM BIOS
When the IBM Setup Utility program prompt is displayed, quickly press F1.
The prompt is displayed for only a short time.
if you dont see the prompt, tap F1 repeatedly as the computer starts. If it says "starting windows" you've let it go too far and will have to restart again and repeat the process to get into the bios
REGARDS..
Apr 09, 2009 | IBM NetVista PC Desktop
IBM NETVISTA P4 2.4G. no O.S.
If your old copy of win xp is not being used by any other computer then reformat the entire drive with xp. Also make sure that your drive is not divided into 2 or 3 sections. All updated will be available on the windows update site. The reason that I prefer tostart from scratch is Everything is new with no lingering Junk programs in the background. Need help email me at [email protected]
Apr 13, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
IBM NetVista PC Desktop Logo
113 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
