Casio wk 1200 sound cuts out - how do I open it up to fix it?
THe sound on my Casio WK 1200 cuts out when it warms up , like on a hot day. The LCD backlight cuts out, (although you can still read it), and the sound cuts out, although you can still hear the sound, very faint and distorted.
This can sometimes be remedied by a sharp tap on the left side of the keyboard, so it might be some loose/dry joint which is temperature sensitive, or a duff capacitor?
However, before I fix this, I have to work out how to open it up! I think I've taken out all the screws, but something seems to be preventing top and bottom of the case from opening. Any ideas, please?
  • rajanben Jul 11, 2008
    intermittent lost of sound Casio wk1200.same problem as mentioned above.already 6925 8890 pcb/assy already changed.
  • Anonymous Sep 10, 2008
    I also have a Casio Wk-1200 and it does the same thing. I realized that when I jiggle the back plugs it tends to work for a while. I also have a problem with the pedal plug-in shorting out as well which requires jiggling. When the sound cuts out on my keyboard (as you mentioned above) I also get this ear-piercing high pitched screeching sound and it scares the **** outta me everytime. I can't stand it. Helppppp!
Excuse Me Im Have Diffuculties Recording My Own Songs Can Anybody Please Teach Me How 2 Record On It?
Posted on Feb 14, 2009
Open battery compartment one screw in there
Posted on Aug 02, 2008
SOURCE:
Free download casio wk7500 keyboard owners manual
Most Casio device manuals are available from the manufacturer's support site: http://www.casio.com/support/manuals/ . Click on the for Musical Instruments and accept the Casio site Terms of Use. Scroll down to the WK instruments and you will find the links for the WK-7500 in the right hand column. The first link on the next page is the Owner's Manual. The file is a PDF so you will need Adobe Reader or a similar program to read or print the manual.
I hope this helps.
Aug 27, 2015 | Casio Computers & Internet
Hi i have a Casio WK 1200 which has midi in and out and also one assignable jack can i use it for microphone for karaoke singing.
I think the assignable jack is for pedal assignable - Sustain, Soft, Sostenuto or Rhythm Start/Stop ONLY
No, this model does not support Mic input for karaoke singing.
Nov 04, 2013 | Casio Music
How do you replace the adaptor jack on a Casio WK-1200 keyboard ? is it easy ?
Unfortunately the adapter jacks are a bit of a weak point on many keyboards but it is quite seldom the jack socket itself that is at fault.
Often the sockets are soldered directly on to the printed circuit board and are prone to either one of the soldered legs breaking, or even the circuit board itself cracking around the jack socket.
Whilst it is generally possible, with care, to resolder a broken leg on the socket if the actual circuit board has cracked the whole board will have to be replaced.
If the actual jack socket itself is damaged it should be possible to snip through the legs and remove it before soldering a new one on to the stumps of the old legs. this is likely to prove easier than trying to solder directly onto the circuit board, unless this is something that you are experienced at doing.
Apparently you can purchase a full service manual for the Casio WK-1200 here for a modest price but I have not used this source myself so cannot vouch for how good it might be.http://www.tradebit.com/filedetail.php/2084335-repair-manual-casio-wk-1200-electronic-keyboard
Feb 02, 2011 | Casio Music
How do you replace the adaptor jack on a Casio WK-1200? is it easy ?
It is easy if you are electronically adept. It invilves opening the unit and soldering, however, finding the exact tyoe of jack to fit may be a problem.
Feb 02, 2011 | Music
When you turn on the wk 3000 the lcd reads pls wait after a few minutes it goes blank no sound no responce
This ONLY applies if you have a floppy or hard drive in your unit...
SOME of these synths hang up during boot if the floppy or hard disk isn't recognized as working...
Also verify your power adapter is producing the right voltage and is the original.
Jul 19, 2010 | Casio Music
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
My backlight is broken (Casio EX-Z100)
Try to check on ebay, you may find the LCD with backlight just less than 30 bucks. To replace the LCD kit is easier to replace only backlight, and it's hard to find the backlight.
Aug 21, 2009 | Casio Exilim EX-Z100 Digital Camera
Need a manual for casio wk 110
Why not download it?
http://www.generalmanual.com/Musical-Instruments/Casio-WK-110-Portable-Keyboard.htm
There;s a link on that page.
All you need to do is google the words
casio wk 110 manual
And you find your answer,
Hope that helps you.
Apr 25, 2009 | Casio WK110 Portable Keyboard
Open Questions:
++++AmaZon PrImE ReFunD PhOnE NuMbER ``+1-++85O++-812+-+4OO9`` Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? ++++AmaZon PrImE ReFunD PhOnE NuMbER +1-++85O++-812+-+4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime?AMAZON PRIME Tech Support Number +1-85O**8I2**4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues.
Oct 20, 2019 | Amazon Computers & Internet
AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime?AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues.
Computers & Internet Logo
821 people viewed this question
Ekse
Alun Cox
