Question about RCA RS2664 Shelf System
RCA RS1285 Shelf System Problem
When cd is inserted "NO DISK" message is displayed
  • bluheavens Mar 30, 2008
    Please tell me where the lens is so I can try to find it and clean it. I don't want to throw the thing out. Flash lite doesn't help.
  • 4,234 Answers
If you can open up the unit and see the CD lens, try cleaning it using a cotton swab and alcohol. The "no disk" message indicates that the optics assembly can not detect a disk. Sometimes this is due to dirt on the lens. If cleaning does not resolve the problem, the optics will need to be replaced.
Dan
Posted on Mar 18, 2008
I need a belt for my 5 disc audio system Where can I get one?
Jaycar or like electronic shops sell assorted drive belts in a pack
Nov 29, 2015 | RCA RS1285 CD Shelf System
I cant find aux bottom on my rca rs1285 cd 5 changer. i want to play music to my mp3 from my stereo using my 3.5mm audio cable
There is no AUX input on your system. That is a headphone output jack, not an input. There appears to be an AUX button on the repmote, but the manual indicated that it does not work. See the link below. Sorry for the bad news.
http://www.manualslib.com/manual/313546/Rca-Rs1285.html?page=6#manual
Oct 18, 2013 | RCA RS1285 CD Shelf System
RCA Shelf System 1285 manual
Retrevo has the manual here: http://www.retrevo.com/support/RCA-RS1285-manual/id/402ci676/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
Jun 14, 2011 | RCA RS1285 CD Shelf System
Won't read disk.
The Laser Pickup Assembly is the problem, the laser is weak, or the pladder motor is bad, One possible option is cleaning the laser lens with a Q-Tip and rubbing alcohol that might restore the system to normal status. The only other option is to have the assembly replaced, a very pricey solution.
Jan 07, 2011 | RCA RS1285 CD Shelf System
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
I can't get the CD player to open at all.
then power protect comes on an wont go off
Feb 08, 2010 | RCA RS1285 CD Shelf System
How to set clock
Follow below procedures to set the clock..
1. Press CLOCK until the time flashes on the display (12-hour clock for RCA, 24-hour clock for Thomson).
2. Press TUNING UP or DOWN to set the hour and then press PRESET UP/ DOWN to shift to minute digits.
3. Press TUNING UP or DOWN to set the minute.
4. Press SET to save settings and STOP to quit setting.
Note: When system is ON, you can press CLOCK to
display the current time for about 2 seconds.
Regards,
Jeep Brainy
Sep 19, 2009 | RCA RS1285 CD Shelf System
I need an Owner Manual and a remote for the RCA RS1285 that I inherited from my mom. Thanks.
Hi I,m not sure if you can get a remote reasonably priced even if you can get one but you could get a universal remote for a lot less and it will probably replace some of the others too , i bought one for 69 dollars Australian and it works for me . Smirf617
Jun 12, 2009 | RCA RS1285 CD Shelf System
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
RCA RS2664 Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
