Question about Dell Dimension 3000 PC Desktop
Windows Xp Reinstalled Xp.. Cant change resolution on Monitor or connect to internet.
  • Dell Master
  • 13,433 Answers
You need to install your computers drivers.
You noted that you have a dimension 3000.
You need videocard drivers to change resolution and networkcard drivers to connect to internet.
Il look for the drivers you need a post them in a minute If i find them.
Posted on Mar 17, 2008
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
I recently reinstalled my windows XP program and added the Dell E173FPc. At the beginning it work perfectly. I then downloaded all the XP updates and restarted several times. I now have a terrible...
Have you tried setting the resolution using display settings in control panel?
Go to control panel search for display. There you will find option to select monitor and resolution.
Oct 01, 2017 | Dell E173FPc 17" TFT LCD Flat Panel...
I have a Mag Innovision 2200W Monitor. I messed with the settings, and now I get a ''mode not supported'' error. The computer is running in the background, and works with other monitors, but not this one....
Hi
To resolve this issue connect a monitor which is working with the Computer. Now right click on desktop and select properties(if windows XP) or personalize/screen resolution (if windows vista / 7)-> Now click on settings tab (windows XP) or change the resolution of your monitor-> Choose a lower resolution rate maybe 800X600. Now try connecting the other monitor with your Computer and it will work.
If not then check for the refresh rate of your monitor, adjust it to 60 Hz. You can adjust refresh rate from settings tab->advanced button(in XP). Screen resolution/Display settings(under windows 7/vista)->Advanced setting->monitor tab ->refresh rate.
This will surely resolve your issue.
Daniel Scott
Jun 08, 2010 | Computers & Internet
Cant use my rad 5 with a desktop Dell computer with Vista
Temporarily connect another monitor to your computer.
Set the screen-resolution to 800 by 600 at 60 Hertz.
Disconnect the other monitor, and connect your RAD.
It should display.
Try changing the screen-resolution to 1024 by 768, and "test" it.
Jan 04, 2010 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Monitor
Install the Drivers. The CD you received is just the basic Windows Install. You can download the drivers at support.dell.com Install order: Desktop System Software (If available) Chipset utility Video Driver Audio Driver Network Driver then install applications like Roxio/Sonic and DVD player
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
REINSTALLED WINDOWS XP PROF. WINDOWS COME UP BUT CANT GET ON INTE
Are you sure you are connected to the internet? You can check that by looking at the right hand corner of the monitor. The icon with two small monitors. When you point the mouse pointer to it, you should be able to see the status: connected. If it shows an X, it means that the cable is unplugged. You should make sure it is fitted on the lan card.
Jul 25, 2009 | Farallon Computers & Internet
Laptop stuck at 800x600
Odd problem. To solve, best bet is too reboot computer, press F2 to enter system settings. Go to visual performance and set a terminal networked computer default. May reset all other setting as well though.
Jul 06, 2009 | Dell LATITUDE XFR D630 Intel Core 2 Duo...
Windows Xp
In addition to installing the operating system (Windows XP) you will need to install the drivers for the system.  If you system is a Dell Dimension 1100 you can get the drivers from this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid=
Driver installation order is:
Desktop system software (R121089.exe) Intel Chipset Utility (R96614.exe) Intel Video Driver (R104515.exe) Audio Driver (R105155.exe) Network Driver (R105786.exe) Modem Driver (R133743.exe or R73044.exe)
Once you have all the drivers installed, then you can install your applications and configure your internet connection.
Sep 07, 2008 | Dell Dimension 1100 PC Desktop
Proview wb926wbi monitor
Try changing the resolution to 1440x900. This is the ideal resolution for this monitor.
To change the resolution:
Right click on an empty space on your Windows desktop.
Choose Properties (XP) or Personalize (Vista)
Choose the Settings tab (XP) or Display Settings (Vista).
Slide the resolution slider to 1440x900, then click apply.
If asked whether you want to keep this setting, choose yes/ok.
Note: Not all video cards support this resolution. Updating your video card's (not monitor's) driver may add it.
Jun 29, 2008 | Proview PL926WBi 19" LCD Monitor
Anyone know a way to increase the resolution past 1024 x 768?
First, you might want to check what the maximum supported resolution of your monitor is. You can do this by looking it up on the internet or referring to the owners manual. If you cant find that information, in your graphics properties in Windows XP, click the advanced button beneath the color settings and click the monitor tab. Make sure the model listed under 'Monitor Type' matches the monitor you have. If it does, see if the 'Hide modes that this monitor cant display' box is checked. If so, the maximum resolution is limited by your monitor and you may have to upgrade the monitor to go any higher. If the model does not match, you can try the following: click Properties->Driver Tab-> Update Driver and either load the correct ones from the manufacturers web site or use one of the Standard Monitor types provided by the windows Driver library. Be warned though: If you select a standard type with resolution higher than your monitor supports, it will not display correctly at settings higher than 1024x768, and you may have to wait for windows to change the resolution back. Another thing you can try is unchecking the 'Hide modes that this monitor cant display' box, clicking ok, and setting the resolution to something higher than 1024x768, but the same warning applies! If it does not display correctly than you know for sure that the monitor is the limiting factor.
Nov 09, 2007 | Sharp LC 28HM2 28 in. Flat Panel LCD...
Dell Dimension 3000 PC Desktop Logo
155 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
