Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Disk is not readable by the computer.
It was working fine all this time. Now I get a message that the disk is not readable by the computer. I run Mac OS 10.4.11 and I was running Final Cut Studio 2.
Footage is 1080 HD.
Please Help!!!!
    Brigadier General:
  • 10,406 Answers
Try a different "data" cable between your computer and the external disk-drive.
Try connecting the unit to a different computer.
If it fails there, then the unit itself has a problem:
Either:
* the USB-to-disk-drive adapter (inside the casing) has failed;
* the disk-drive (inside the casing) has failed.
Disassemble the external unit, and remove the disk-drive. Connect it as a "slave" disk-drive in some Apple Computer, to see if the data on the disk-drive can still be accessed.
Check with LACIE, to see if their "warranty" is still valid, or if it has expired.
Posted on Apr 08, 2010
SOURCE:
Disk for Zip 750 Firewire is not readable
sometimes you get this problem if you have changed software version what software was you using before and are these zip disks off your comp originally or from another sourse you could try reinstalling the software that came with it or if dont have software you should be able to get it off the net hope this is some help ...............................................
Nov 08, 2007 | Iomega (32453) External ZIP Drive
I have a transcend 500 GB hardrive, and it was working perfectly fine, but now when i connect it to my mac, a message pops up saying "The Disk you inserted is not readable by the computer." I...
First, connect the hard drive to the computer. Go to the search bar in the top right and search: Disk Utility. Then select your hard drive (not a subsection, the actual hard drive). go to the First Aid tab, and click "repair disk".
If this does not fix it, then I am afraid that your drive is dead.You may have abused the product in some way (dropped it, dropped it while it was on, bumped it, didn't drag the drive to the trash can, etc).
Feb 25, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
courtesy of Microsoft.com
Oct 14, 2010 | Acer Aspire 5315 Notebook
My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Jul 10, 2009 | Western Digital 500GB My Book World...
I just bought a apple laptop yesturday, came with 2 install disks, and installed the first one, and second is the mac os x, the install starts but then says "disk isnt readable", to take it out and clean...
The Mac should work right out of the box! You don't have to install anything. The install disks are ONLY if you need to re-install the operating system which is a once in a lifetime event!
May 03, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
I have one of the first digital cameras which I bought over 8 years ago from AOL. When I use a new disk in the camera it works fine, when I insert the disk into my computer running Windows XP and upload...
i think that the xp os reconfigures the disc to a readable format. hence it doesent work backwards.
if you try it on windows nt, it should start working
May 20, 2008 | Cameras
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
426 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
