Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
AKAI Rear projection...
Thank for the reply!
OK. where do I find the tuner solder joints, pins where the input board feeds the signal board?
Sorry but I am not even a little bit of a techie! lol
  • Akai Master
  • 8,617 Answers
The back panel of the tv where the inputs go. that panel is usually attached to the signal board by clips. Resolder the clip pins on the back side of the signal board. The tuner should be a small rectangle box with a coax cable coming from it going to the coax input on rear panel. resolder where that tuner attaches to the signal board.
Posted on Mar 17, 2008
How to change a tuner on mitsubihi dlp tv?
Set may have two tuners or a combined one (no model here) and average cost is well over 100 just for the part--it is soldered in.
IF the tuner is bad there is another option---if a DVD etc works via rear audio/video inputs you can route with a box signal in the same way to one of those inputs---bypass the tuner and use the box for signal and changing channels.
Google the model number of the set with "parts" if you want to try to locate the tuner or the entire board (may not be available).
Jun 12, 2012 | Mitsubishi Televison & Video
Akai pt4298hd
Look at AC power supply board they are bad about poor solder joints resolder thyrisitor on board.
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
After installing the two converegence chips,(stk-392-110)the tv powers on for maybe two seconds then shuts off. I took the board back out and checked all solder joints,they were all ok.when powered on I...
Yes - You most likely created a short by soldering the convergence chip pins together. Go back over your soldering and fix any bad spots. No two pins should be touching.
Ed
May 10, 2009 | Hitachi 43FWX20B 43" Rear Projection...
2006 Akai 23" Led TV says it gets no signal.
hi, the input blocks are where you will need to look for this problem. sometimes these block connection become lose and detached from the main logic board. this could happen due to a minor crack in the solder or to much pressure when inserting cables and input rac jacks etc.. replacing or repairing this section of your TV's board will fix this issue.
Feb 25, 2009 | Akai PT4298HD Rear Projection Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Conrac Plasma Display 4042
Found cold soldering point on tuner board.
Sep 11, 2008 | Fujitsu Plasmavision PDS-4203 42 in....
Rear projection TV! HELP!
Try looking over the tuner solder joints as well as the pins where Input board feeds to the singal board. Sounds like a solder issue or a weak capacitor. Check the solder with a good quality magnifying glass. Let me know how you make out and I will try to help you through the process to nail it down.
Mar 16, 2008 | Akai PTH5498 54" Rear Projection...
No sound on analog inputs, digital sound is ok
1) IT02 Shorted, pins 92 and 93
Cause: Solder splash
2) IT05 pins 20 & 21 shorted.
Cause: Seems to have been cause by too much solder.
3) IT02 was found to be defective.
Cause: Defective component.
4) IS11 missing circuit trace.
Cause: Caused by some one that replaced/removed this IC previously.
5) IT02 solder, pins 42, 43 & 44
Cause: Two boards found with these same pins with cracked solder
6) IS13, pins 1 & 2 shorted
7) Audio Quits when board is tapped.
Cause: Soldered all IC's on bottom of board. Also soldered IT04, I516, I517, I510, I501.
8) Also, please resolder IT05 and IT06
9) Check for cracked patterns under IT05
Dec 10, 2007 | Hitachi 53SWX12B 53" Rear Projection...
No Picture Audio Only
It sound like the components are ok. Are any of the component leads discolored from excessive heat? If so it may be that the resolder looks ok but is not actually adhering to the lead. Use solder wick or a desolder iron to remove the old solder, clean the lead(s) by scraping with a sharp knife edge to bare good metal and resolder.
Dec 08, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
