Question about Admiral AW22 Top Load Washer
Washing machine I have an Admiral top loading washine Model # 7010L0Aus APP Marking N/13543 ser # 011843. Inside the agitator shaft there is a round plate with a hole in for the water/conditioner to go through, this plate has dislodged and is off centre. This area gets "gunky" stuff in, l clean it out but would like to know if l can get the agitator out to be able to clean better and also be able to straighten that plate.
    Scholar:
  • 116 Answers
Sounds like the agitator securing bolt is missing and what you see is the remaining washer (" a plate with a hole in"), if the bolt is missing the agitator should simply lift up to remove, the securing bolt is a 10mm x 40mm should do the job, you will need a 17mm socket and long extension to refit the securing bolt.
Posted on Apr 13, 2008
SOURCE:
Admiral washer will agitate but will not spin dry
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | Admiral AW22 Top Load Washer
Where is lint coming from in washine machine?
i can tell you how to take agitator off but thats not your problem,,please send valid model number...onthejob
Jan 16, 2009 | Kenmore 24032\24036 Top Load Washer
Admiral Top load washer won't agitate and squeals
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Jun 28, 2008 | Admiral AW22 Top Load Washer
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Apr 15, 2008 | Admiral AW22 Top Load Washer
Admiral Top Load Washing Machine
I had this recent, as well. The plastic grooves are wearing down, so there's nothing to hold it together with. I got some gorilla glue, and put the agitator back on the metal part that comes out of the motor. I let it set over night to dry. It's worked since I did it, and the agitator stays down...
Mar 18, 2008 | Admiral AW22 Top Load Washer
Admiral model lnc6543a80 washing machine
IF TIMER IS NOT ADVANCING ,BUT WASHER DOES FILL AND AGITATE, THE PROBLEM IS THE TIMER . REPLACE TIMER.
FXIT
Jan 30, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
88 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
