Question about Refrigerators
Won't make ice
Tube keeps freezing in freezer, how can i get it to stop? Have turned freezer off & defrosted Still does sme thing when turned back on, also changed filter recently
    President:
  • Refrigerators Master
  • 2,651 Answers
Some times low water pressure will freeze drain tube, a badwater valve wont give enough water quick enough and tricling water will freeze ion a a week or so its frozen!
Posted on Mar 18, 2008
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
I have a Kenmore upright freezer model# 253.9260210. We noticed that our food was starting to thaw. I opened up the coil area and noticed a small piece of ice on the coils. I melted the ice and turned...
Feel top of the compressor and tell me how hot after it has been running awhile. I need also that you advance the defrost timer=>. 216517400 Defrost Timer
clockwise slowly untill the compressor stops or starts. I need to make sure the timer is not stuck into defrost. I want you to leave the compressor off for up to 35 minutes. If the freezer compressor doesn't restart bt then simply again turn the timer clockwise slowly until it does and then stop turning. The defrost timer is location 23 in this photo HERE If you need to turn the defrost timer like this to restart the compressor then replace the defrost timer and this will resolve the freezing problem. If not we move to the defrost heater location 14 in the sme photo=> 216254600 Defrost Heater
I am going to stop here until I hear from you, Thanks Sea Breeze
Dec 08, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer won't stay cold. ice cream will not
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 14, 2011 | Kenmore Refrigerators
The freezer side of my refrigerator won't stop
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 07, 2011 | GE GSHS6KGZSS Side by Side Refrirator
Hello : I have a Samsung refridgerator about 8 years old and my problem is with my control panel . It won't keep acurate temperature . The refridgerator stays somewhat cool and the freezer won't...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 06, 2011 | Samsung RS2534 Side by Side Refrigerator
Freezer stays cool but won't freeze
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 06, 2011 | Kenmore Bottom Freezer French Door...
My fridge freezer, it stopped getting cold, t in the fridge and now the freezer won't freeze. so i turn it off and left it off all day, turn it back on ,the freezer is getting cold but not freezing...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 29, 2011 | Admiral 26 cu. ft. Side-By-Side...
The freezer fan just shut off on my frt105gw refrigerator. Is this normal? It wasn't keeping things cold a few weeks ago, I unplugged it, and plugged it back in, and seemed to start working. Then...
Some freezer fans won't work unless the temp in the freezer is low enough. About 10 degrees or so. Try these next.to get it colder
NOTE: This
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 02, 2011 | Frigidaire FRT105GW (10 cu. ft.) Top...
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Jul 07, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
REFRIGERATOR dRAIN stopped up
SOME REFRIGERATORS HAVE A CUP IN THE BACK OF THE FRESH FOOD COMPARTMENT THAT CATCHES THE WATER AS IT COMES FROM THE FREEZER AND SENDS IT DOWN THE DRAIN TUBE INTO THE DRAIN PAN. IF THE DRAIN TUBE OR CUP GETS A RESTRICTION IN IT, IT WILL OVERFLOW AND BRING WATER INTO THE REFRIGERATOR. CHECK THE CUP AND DRAIN TUBE FOR RESTRICTION.
SOME REFRIGERATORS HAVE THE DRAIN TUBE BUILTIN TO THE WALLS OF THE REFRIGERATOR, BUT THE HOLE IN THE FREEZER IS SMALL AND FREEZES OVER. WHEN THE DEFROST CYCLE COMES ON, THERE IS A BUILDUP OF ICE THAT CAUSES THE WATER TO FALL DOWN THROUGH THE AIR DUCT INTO THE FRESH FOOD COMPARTMENT. YOU WILL HAVE TO REMOVE THE BACK WALL OF THE FREEZER AND SEE IF AN ICE BUILDUP UNDER THE COILS IS PRESENT. THEN, REMOVE THE ICE, CLEAR THE DRAIN HOLE, AND SEE IF WATER WILL PASS THROUGH THE DRAIN. A FIX TO PREVENT FREEZEOVER FROM REOCCURING, IS TAKE A PIECE OF BARE COPPER WIRE AND WRAP AROUND THE DEFROST HEATER AND PASS IT DOWN THE DRAIN HOLE (ABOUT FIVE INCHES WILL DO).
WHEN THE DEFROST HEATER COMES ON, IT WILL PASS HEAT DOWN THE WIRE TO KEEP THE DRAIN HOLE FROM FREEZING UP.
Apr 16, 2008 | Refrigerators
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
