Question about Casio Exilim EX-S600 Digital Camera
Not charging Hi, The charger LED keep flasing red on craddle...not sure if it is charging or not. Please advise what had gone wrong. thanks,
  • 200Sandra Mar 18, 2008
    I am trying to charge my Casio Exilim EX-5600 Digital Camera. When it first starts to charge the LED stays red, and then maybe 30 seconds later the LED light starts to flash red and will not charge. Please advise what I can do to recitify this problem.
  • Yaliina Mar 19, 2008
    Me too! My camera suddenly won't charge- it just flashes red!! I really needed it tonight, too!! :( Hope somebody has an answer for this some time soon.
    I've unplugged/replugged (of course) every part of it. I blew on the contacts. I don't know what else to try. It blinks- so it recognizes the camera is attached, but there's an issue. If I push the Photo button the camera LCD comes on & displays the menu. But the lens won't open. (battery fully dead). This is less than 1 yr old.
Same thing happened to me and I've found 2 solutions:
1. Casio has recognized that this is a problem with the battery. If you call the support line and tell them the problem, they will send you a new battery for free. All you need is the serial code on the bottom of your battery.
2. This sounds crazy but it worked for me. Take a 9v battery and touch the connectors to the connectors of your np 20 casio battery. make sure to touch + to + and - to -. hold it there for 30 -60 seconds. put the np 20 back in the camera and put the camera on the dock. this will give it just enough charge that the charger will recognize the battery and start charging your camera to full.
Posted on Mar 19, 2008
Here is how you fix the problem (without using a 9V battery!).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
Posted on Jun 15, 2008
Perfect! I did the repitition thing for at least 20 times... and it worked! Thanks Elizabeth! Ciao Joey (Netherlands)
Posted on Jul 15, 2008
Just tried the 6-8 repetitions thing and it works!!!! My baby's charging! God I love these forums!
Posted on Jun 18, 2008
The 9v battery worked GREAT! Who would have ever thought? $300 for a camera, and .99 cents to make it work!
Posted on May 17, 2008
Valence, you ROCK!!! That 9v battery fix FIXED MY PROBLEM!!! I'm still calling Casio for a new battery- I don't want to always have to keep a 9volt on-hand (plus, I paid enough for my camera it should darn-well work). But THANKS for that fix!!
Posted on Mar 28, 2008
I was told by one of the techs to put the battery in a freezer for a couple of ours to reset it worked for me hope this helps
Posted on Mar 27, 2008
I called Casio as well. My camera was under warranty so they are sending me a new battery too!
Posted on Mar 21, 2008
I called Casio and indeed they are sending me a new battery. Many thanks for the solution!
Posted on Mar 20, 2008
Ideas Arlec PS906 mobility chair charger. It's saying that battery's charged, only on with one red light when charger off, all lights on when charger attached. It turns on but lowest of power, Elaine
Hi again I'm a bit confused a PsS906 arlec charger is a 12 volt charger ??? Can u supply more information .cheers Hi when u turn charger on red ( led ) should come on / when connected to battery / red & yellow ,( led ) should b on /it's in charging mode /when green ,,( led ) turns on battery is charged.cheers
Dec 09, 2017 | Health & Beauty
Charging light shows green--manual says charged when light goes off-_I would expect a red light when charging--Is it charged when green light shows???LUMIX ZS8
Hi if u r using DE-A60 or DE-A60A CHARGER / when charging green LED is on when fully charged LED Turns off ...cheers
Nov 01, 2017 | Health & Beauty
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Battery will not charge
Here is how you fix the problem (without using a 9V battery method...).
Bingo, no problem!
Jul 10, 2008 | Casio Exilim EX-Z57 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
LG 4010 Charging problem?
your carrier will likely give you a new charger and battery.
there is upgrade credits available and if you do not get a new phone each two years, you probably qualify for some free parts.
one employee told me he told the carrier that his phone was defective and that he could not afford a new one, so he wanted to close his account. they insisted on giving him a new phone instead, at no charge.
m
Dec 30, 2007 | LG C1300/L1200/4010/4050/L1150/G4015...
Camera Will NOt Charge
go for the new charger. Keep the battery, always good to have a couple of batteries[I have 3 lions and when I was using AA's I had 6 sets of 4.
Aug 19, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
402 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
