Question about Vivitar ViviCam 5386 Digital Camera
Lens Error I have installed new batteries in my camera, and when I turn it on, I get a message that says Lens error. The batteries are installed correctly, what do you think the problem may be. Thanks
  • terrickbridg Apr 29, 2009
    I have the same problem and I don't recall dropping the battery. This problem has happen before and one day when I turn it on it was okay. Well since Feb'09 after leaving my camera on my lens got stuck, but eventually closed. Now when I try to turn my camera on it just says Lens Error and then cut offf. How can I fix this?
    Problem Solver:
  • 13 Answers
It sound like your lens is either jammed or the motor that causes the lens to open has a problem. First try spraying a can of compressed air around the lens while you turn it on. Also make sure that you are using high output batteries. Digital camera's require high capacity batteries to operate properly but if you are getting a error message then that means that the camera is turning on. Usually if you use regular batteries the camera will just cycle on and off but the lens will come out and go back in. Has this camera been dropped?
Posted on Mar 22, 2008
My digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
Lens error, lens do not open
Jul 14, 2010 | Canon PowerShot A1100 IS Digital Camera
When i turn on, it says lens error, restart camera - i"ve turned the camera on and off several times and nothing happens, the error message continues to show. I've taken the battery out and put back in but...
Jul 05, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
I have a Nikon s220 coolpix and everytime I turn on the camera the lens opens, makes a strange noise and closes - it does this 3 times and then I get a lens error message on the screen. Do you know what is...
Jul 02, 2010 | Cameras
Lens error; restart camera
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
Lens error :0x01110000 That's what it says when
Jun 12, 2010 | Pentax Optio 60 Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
Lens error
May 31, 2010 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix L4 Lens error
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Dec 08, 2008 | Nikon COOLPIX L18 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Vivitar ViviCam 5386 Digital Camera Logo
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
