Samsung sp42w4hb rear projection screen fault on picture looks three like 3d can still see whats on but green and red thought is it lamps or ??
  • 1 more comment
  • tv12345678 May 12, 2008
    hi i have the same problem but iam looking to find out if the ics is the only fix if the resistors are burnt and you cant see their value where would they be located and if its not them what other things should i try i will replace the 2 ics if it dosent work where should i look next and if the ressistors are to blame what are their numbers as i dont have a clue no manuals i want this big tv back in the daughters room hopefully fixed as soon as possible cheers,
  • paddsuk Jun 15, 2008
    i have same prob to ,wot do i do exactly or will the problem be obvious when i see it ,thanks
  • MrBont Apr 22, 2009
    I have replaced the stk ic's and some resistors that were giving a bad reading, but my red convergence is still way off. Am I missing something else?????
  • 372 Answers
Hi.
The 2 convergence ICs will need replacing.
Providing you have got soldering iron with no bigger than 1,2mm tip desoldering braid & heat sink compound you can do it your self.
The convergence ICs are mounted on 2 x large aluminium heat sinks with fins on, The ICs will have STK 392 **** stamped on them.
http://dysonmanuals.llc.nu/
Posted on Mar 21, 2008
52inch projection screen television has only red and green colors and its difficult to see the picture.
If the picture looks 3d with lines bowed it may be a convergence problem---go into the customer menu and call up convergence and at least look.
Aug 27, 2012 | Samsung PCJ522R 52" Rear Projection...
There is red and blue lines around screen and images. (Almost looks like it should be 3d). Does this mean it needs a new lamp/bulb? It is only 6 years old. What is the cost for the part? Thank you
If model number is as listed (46f500) it does not use a lamp or bulb but has three picture tubes.
3d means the two convergence chips in the set have failed.
It depends on if you can solder etc, not a very expensive parts cost (under 30 dollars)
Can you solder?
SD TECH
Sep 17, 2011 | Hitachi 46F500 46" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
The picture looks 3D
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung projection tv
This is most likely a convergence problem. Does the picture look like 3D? If so, please confirm that the model is PCL541R and I'll rpovide additional details and instructions.
Dan
Sep 24, 2008 | Samsung PCL541R 54" Rear Projection...
Rear screen projection tv
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 30, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung rear projection tv sp42w4hb
I would check the CRT socket module for Cracked solder joints. If not you may be in the early stages of the CRT shorting, If so you will need a new CRT.
Jan 04, 2008 | Televison & Video
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
605 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
