Question about Samsung TXK3276 TV
No sound Started to wire aux. speakers and accidental touched the two speaker wires together and now no sound
    Novelist:
  • 236 Answers
If you had the speaker wires shorted for a while and boosted your audio waioting for a sound then your audio power amp must be busted. If this model comes with a protection fuse, then it usually blows the fuse and just replace it otherwise if it's a type that doesn't use then only reason why no sound is busted power output amp.
Posted on Mar 17, 2008
  • Anonymous Mar 18, 2008
    any development?
    Red
SOURCE:
What can it be that the radio light up but no sound
This is kind of a loaded question. We first need to know the make and model of the car, then we also need to know if it is a factory or aftermarket stereo. Some simple things to check - Make sure bluetooth is not connected to any devices (if the vehicle has bluetooth). Check that nothing is connected to any audio ports. Also, make sure it is set to the preferred station you wish to listen to (FM, AM, AUX, etc) and you aren't accidentally on the wrong input.
Other issues could be faulty wiring, bad speakers, magnet on speaker touching metal on door, etc, etc. There are loads of possibilities, unfortunately.
Feb 23, 2017 | Cars & Trucks
Speaker wire
Sorry to hear that. you may have blown out the internal amp channels in the stock radio.
Jun 02, 2013 | Buick Cars & Trucks
When car is hooked up I get visuals, lights. etc. but no sound transmits from the stereo to speakers. I have checked all speaker connections and RCA jacks, along w/ amp and subwoofer and all are connected...
The illumination wires (orange, not yellow. Yellow is for 12 volt in) would not have an effect on sound. Either the internal amp is blown or you have a shorted speaker which is preventing the internal amp from turning on. Disconnect all speakers and hook a KNOWN GOOD one to an output. I f you get sound, the problem is in the car, if not, the problem is in the radio. If you accidentally crossed two of the speaker wires or let one touch a chassis ground, you blew the amp.
Jul 01, 2011 | Car Audio & Video
Just bought jensen uv8 touch screen and installed speaker wires will produce no sound except for sub input on rca please help?
it could be a case while you or someone installing the unit could or might have blown out the speaker output of the unit
try taking the unit out connect the red(acc wire) yellow(constant wire) together connect the black(ground wire)
get a test speaker and see if u get sounds
Jan 26, 2010 | Jensen VM9510 Car DVD Player
Speaker wires accidentally touched.
it sounds like the cone in the centre has blown. Use a 'spare speaker' not one from the system and try it, is should work, but if it was the centre speaker cable that shorted, should you get no sound from the spare it sounds like you have blown that part of the system which will require professional repair. Sorry
Jan 17, 2010 | Yamaha HTR-6030 Receiver
Receiver doesn't turn on, trips out
sounds like a cross wired speaker, or a wire is touching either inside the speaker box, or the actual wires are touching at the terminals. this is simple to remedy unplug everything from receiver, then with it turned on and at a low but audible level. plug each one in till the problem occurs again. the time it occurs will say that you found the problem speaker. good luck. also manipulating wires often corrects any problem with wires touching accidentally.
Dec 14, 2009 | Yamaha HTR-5890 Receiver
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
Integrate computer (huge MP3 library) into home theater sound (AIWA's fantastic speakers)
Sounds like the wiring for the speakers has been modified to bypass the crossover. Best to open up the speakers and see if there is a crossover. Both speakers should be wired to a crossover and the crossover wired to the speaker out on the amp. Crossovers can be bought from Jaycar in Aust or Madisound in US
May 12, 2009 | Audio Players & Recorders
Speaker system
This definately means that you have a positve and negative speaker wire touching somewhere. First thing to do would be to check all connections at the speakers and on back of receiver and make sure all wires are seperated. This is a common problem if two wires are touching each other. If you check all connections and they look ok and you still have same problem you need to start unhooking all wires and hook them up one at a time and turn on system. If it works with one speaker then try hooking up a second speaker wire and so on until it gives you protection message again. Basically process of elemenation. Once you says that protection message you need to replace the last wire you hook up all together as you could of damaged it when running speaker wire or it could be a defect in speaker wire.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Samsung HT-P38 System
Samsung TXK3276 TV Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
