Question about RCA P52937 52" Rear Projection Television
Tv turns off after it gets hot
My RCA tv comes on fine and works fine for maybe 5-10 minutes. Then it shuts off and comes back on for another 5 minutes. Then it seems to shut on and off, on and off and you can hear it popping and crackling in the back of the tv. If you let it cool off it will work again but the same thing happens. My set was manufactured in 2002.
    Master:
  • 518 Answers
RCA TV's of that vintage are known for having bad solder joints in the power supply stages and they become very remperature sensitive.
Geno
Posted on Mar 18, 2008
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Jan 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Just replaced the bulb. the tv works fine for 5
Ck Fan to Lamp it maybe Defective if fan stops running then lamp shuts off this is to protect Lamp from getting to hot Call Mats for Parts if it is the fan and Ballast Board is what turns Lamp on. 1-800-628-1118 they sell all supplys for TVs
Sep 26, 2009 | Sony KDS-R50XBR1 50" HDTV
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Working fine, then shut off.. won't come on, no power
A clogged air vent will cause the unit to overheat and not turn on.
Apr 16, 2009 | RCA D52W19 52" Rear Projection Television
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Television
maybe the power switch of your tv is loosen,if not you may coldsolder the components of board of your tv.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
Sound is fine, but no picture
could be a bad solder connection or maybe the CRT socket has come off slightly. I lean more to a bad solder connection at the flyback area screen G2
Dec 14, 2006 | RCA F36650 36" TV
RCA P52937 52" Rear Projection Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
