Question about Sharp AR C250A Color Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Can anyone tell me what to do to fix the above error code for SHARP AR C250 Digital Color COPIER. SERVICE CODE H4 00. The copier w working fine up until the service code came on
  • Anonymous Mar 24, 2014
    Sharp ar-M351N digital copier CE-00 error code solutions.
    thanks
Me podria enviar otra solucion al problema que se presenta en la parte superior SHARP AR C250 Digital Color COPIER. SERVICE CODE H4 00. pero en español porfavor
Posted on Nov 17, 2008
    Scholar:
  • Sharp Expert
  • 120 Answers
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Posted on Jun 15, 2008
SOURCE:
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
H5 flashing on the display, anyone tell me what the error is please? It's a Sharp AR-161 copier
H5 doesn't show up on the service code manual. However, all error codes beginning with 'H' are related to the fuser, this is the heating portion of the machine. Be careful if it still prints despite the error code, you may damage the unit. It should be looked at by a service rep.
Jan 12, 2010 | Sharp AR-161 Laser Printer
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error U3 on a Sharp AR-5132 Copier
The problem is on the mirror section on the scanner unit. It might be the motor, sensor, scanner wire or just need lubricating. I think you better call your local tech.
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error U2 on a Sharp AR-5132
There are 3 different U2 codes, but all are kinda related. They are all communication related errors to the MCU board. Firstly make sure the developer unit is in securely. You try canceling the error code by going into SIM mode. press the following keys one after the other "#" "interupt" "C" "interupt". enter 14 and press start, this should reset the copier. make sure the copier is restarted.
If reset does not work and developer unit is in securely then it would more than likely require a technician.
Hope this helps.
Apr 05, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error Code F1-00: How to clear on Sharp AR-C250
go into service mode (program interrupt clear interrupt)
enter simulation 26 sub 1 (option setup)
change to no finisher
CA to exit, and you're all set
Dec 11, 2008 | Office Equipment & Supplies
the machine is detecting a low temerature in the fuser unit. a commen cause is the thermistor digs into the fuser roller and tears the outer skin and the roller. you can check by opening the front door slide out the main unit open the door on the left hand side and you should see two orange rollers. check if the upper roller has a line around it.
Nov 17, 2008 | Sharp AR C250A Color Copier
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Sharp AR-5316
enter the following code.
cancel -- interupt -- zero -- interupt - the display should switch off then enter 14 and push the copy button- copier should reset if not heater lamp could be blown
May 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR C250A Color Copier Logo
789 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
