Question about Vacuums
WE NEED A HOSE RACK FOR A EUREKA CENRTAL VAC 36FT.HOSE IS ONE AVAILABLE OR WILL ANY GENERIC HOSE HOLDER BE SUFFICIENT. cwcromp@ns.sympatico.ca
    President:
  • 1,673 Answers
Any shop or store that sells central systems will have hose hangers, any one should work.
Posted on Mar 21, 2008
Central vac is Eureka Altima CV1801M. Tripped the circuit breaker when I turned it on. Discovered bag was full. Replaced bag and now vacuum won't power on without tripping breaker. Any idea what could...
Ok thiese are my specialty. Somemodels have a cloth filter, make sure it is clean. Also check the hose or pipes for a clogg. The best way to do this is turn the machine on, put hose in, if the motor winds up like its labouring there is a clog in ther hose. Do this with every inlet and listen for the same. If the vac. is hot it will not turn back on until it cools. Hope this helps, if not let me know. Chris
Feb 06, 2011 | Eureka CV1801 Bagged Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
I need a replacement hose
You can get the nose part number and order the part at this URL:
http://www.VacPartsWarehouse.com/Eureka-3041-Enviro-Vac-s/1859.htm
Oct 02, 2010 | Eureka 3041BZ Upright Vacuum
Eureka Altima (yellow)
the hose under your dusting tool, remove that and you should see the clog. i had the same issue and also found that the smell that is emitted went away after i unclogged it
Aug 24, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Something is stuck in my hose on the eureka boss smartvac, can i dtach plastic hose on side
yes, there are a few screws that need to come out to do so, u can also use a coat hanger to loosen it up and turn it on, the vac will **** the loose dirt into the bag/canister
Jul 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the Boss Smart Vac. Hose has suction, but still isn't picking up. Weird.
Your belt is probably broken. Check your belt and make sure your brushroll has not seized. If both of those check out ok, (because the smartvac belt doesn't stretch,) the belt tensioner assembly may have gone bad.
-R
Aug 11, 2008 | Eureka Vacuums
MY EUREKA WORLD VAC ROLLERS ARE NOT SPINNING. THE LIGHT IS ALSO BURNED OUT. IS THERE A CONNECTION BETWEEN THESE TWO EVENTS?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=813214
Generic problem for all Vacuums
Posted by agreene1038 on July 21, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the Eureka brushrolls have a sensor in the brushroll that indicates that the brush is moving and the sensor and the light are linked together – you may have a bad brushroll – to check that you need to remove the brushroll, stand it on end and spin it freely, if it does not spin the bearings could be bad or needs to be replaced with a new brushroll and a new belt. The belt change is every 4 to 6 months for the best cleaning. . If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 21, 2008 | Vacuums
Eureka Wide Track Superlite Vacuum
Eureka doesn't make these motors available. Best to just replace the stick vac with a new one.
Jun 14, 2008 | Eureka 421A EZ Kleen Bagless Stick Vacuum
Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Go Ahead. Use Us.
Jun 07, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
