Question about Philips 42PF9631D 42 in. Plasma Television
Damaged screen hi ive scratched my plasma an its left a little white dot,wot would i need a new screen?
  • fadwati Dec 03, 2008
    I have a white dot on my screen, seems like a scratch because it has hard edges,, what can I do? my model is samsung LNT4665FX.
  • 4,234 Answers
Without the make and model, I can't say for sure that a replacement is available that would be affordable. Some plasma sets have a protective covering, some do not. Replacing the plasma panel will be almost as much as replacing the entire set.
Please post the make and model.
Dan
Posted on Mar 18, 2008
White screen
did you drop it in water, ?did you press the screen to hard and cracked the lcd panel? those are the most common reasons, oh, and dropping it, and also dropping it in water. I would suggest going over all those possibilities.. open up the back of your phone and pull out the battery, in all phones now they have a water sensor dot, it remains white always unless the phone was damaged by water, and warranty doesnt cover water damage, look for that little white dot, if its red, that means you gotta get a new phone, and if you try peeling if off theyll know youre covering up water damage, unless you were able to somehow obtain another white color changing dot to put back in your phone now in the exact place it should be, but techs are very good at catching bluffs. but if that white is intact to begin with, your phone should be under warrenty of some sort, and that means they owe you a new one. bottom line. BOOM
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
White dots appear on my screen
that sounds like a common effect that plasma sets develpe ehen the voltage on the screen driver is set out of spec, or the plasma screen assy is going bad, 90% of the times that I have adjusted the voltage the sparkling effect came back, indicating that the plasma display is going bad. or the power supply is going bad, most of the time dried out or bad capacitors in the main power supply in the set. I wish I would have written down those capacitors values and their numbers., as I remembered I found the bad caps because the tops were swollen a little bit. not yet bad yetr but on thier way their. and if left unchecked they will blow up and causing a lot more damage to the power supply
Techman
May 18, 2010 | Samsung HL-S5086W 50" HDTV
White dots in plasma tv
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
Aug 15, 2009 | Televison & Video
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Dell W3000 display issue - band of red dots on the left side
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 11, 2017 | Dell W3000 30 in. HD-Ready LCD Television
Broken screen
i have a 42"pd6600 which has a broken pcb board, my house insurance got me a new samsung 1080p and left me with the hitachi also. the set still works but flicks from picture to dark due to the pcb which aparently costs more than £400. would you like to buy it?
Aug 04, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Philips 42PF9631D 42 in. Plasma Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
