Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Crazy icons I am seeing the word Rubrica, E with // under it up at the signal area, and an A in a square with a > on the left side of it; does any of this make sense? Also, why would I not be able to download pics that friends send me?
  • treschandler Mar 17, 2008
    Also it keep shutting off and going to the boot loader screen?
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and have them reflash the firmware on your phone to correct your issues.
Posted on Mar 28, 2008
Need English Manual for SANEI N78 7 inch Android 4.1 RockChip Dual-core RK3066
If you haven't resolved the language issue yet, try this:
1. power up the tablet by pressing the power button on the left side of the top edge of the tablet
2. slide the lock to bring up the home screen
3. across the top of the screen you'll see a magnifying glass (top left), a microphone, a folder with three dots on it (center) and dark area on the top right corner with six blue squares in it. Press the squares. Now you'll see your apps.
4. swipe your finger across the screen from right to left to show the next screen of apps. Look for the Settings app. It's grey with a light grey gear/sprocket in the center. Press that and you'll go into the Settings screen.
5. Down the left side you'll see a menu of options. Look for the Language and Input option. It is the one that looks like a solid light coloured square with the letter A in the center of it. Press that.
6. when that's hightlighted on the left side of the screen, you'll see the language option at the very top of the right side of the screen. There's no icon beside it, but it's the very top option. Press that.
7. the twelfth option in the list that comes up on the right side is "English (Canada)". Count down to the twelfth option and press it. The language of your table will be English. Go back and change it to something else if you don't want that particular English option.
Hope this helps. I found this youtube video that might help, too.
http://www.youtube.com/watch?v=e_rK6WRT3Ps
Skip ahead to 2:38. That's where he turns it on and then he changes the language (he could be changing it to Spanish, but you'll get the idea).
Mike
Apr 01, 2013 | Sanei Freescale IMX6Q Tablet PC
Where is the turn signal relay on an escort 1992
you have a fuse box under the dash and a fuse/relay box under the hood.
Althou many cars will place the flasher/blinker relay under the dash near the brake pedal, and still, some are behind the radio (farther back and close to the floor)
here is the relay you are looking for.
You can turn on the hazard flashers and listen for the ticking sound the flasher makes. Follow the sound and look for a small round or square piece. (the flasher)
You should have one for blinkers and one for hazards.
This flasher is most often the problem.
Relay may be in the area if not under hood.
Dec 14, 2012 | 1992 Ford Escort 4 Door
Where is the turn signal flasher on a 1995 Chevy Silverado?
On my 95 Chevy 1500, the 4way flasher is located in fuse panel on firewall driver side under dash. To get to the turn signal flasher, remove the bottom dash panel and the entire ash tray compartment. I also removed the cup holder unit to allow light. The turn signal flasher was located just below the the radio and AC area. Mine was wrapped in tape from the factory, but if you turn the turn signals on you will feel the vibration and be able to locate it from the sound.
Apr 25, 2012 | 1995 Chevrolet C1500
Left turn signals don't work, but rt does.
turn signals need full 12.7 battery voltage to work sometimes when the batt is loww only one side will blink ,if the flasher is bad sometimes only one side will blink charge ur batt and try again a quick check to see if both sides are wired correctly or that the wires to the side not working is to unplug the flasher a small square box sometimes under tank or left side cover and jump the two wires and put blinkers on each side they should come on but not blink and that will tell u if ur flasher is ok or not good luck!
Aug 23, 2011 | 1982 Yamaha XJ 650
I have a Dell Inspiron 531S, I have both two different monitor slot, does my PC support dual monitor systems?
Yes.
The area on the back of the computer, that has two ports to connect a monitor, is a Graphics Card.
It is a PCI-Express graphics card, and is plugged into a PCI-Express x16 slot on the motherboard.
(Expansion Slot)
It has a blue VGA port, white DVI port, and black S-Video port.
The area on the upper left with a blue outline around a VGA port, is a VGA port connected directly to the motherboard. It is Integrated Graphics.
You CANNOT use Integrated Graphics, and a graphics card at the same time.
It's either use the Integrated Graphics VGA port, OR use the graphics port/s on the graphics card.
BIOS will Not support using both Integrated Graphics, and a graphics card.
HOWEVER, you can use the VGA port, and the DVI port when using two monitors.
You will be only using just the graphics card.
Example of a VGA port, (Connector), and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/DVI_connector
1) Whatever monitor you have that has a VGA cable, plug it into the blue VGA port on the graphics card.
(There are VGA monitors {CRT} that resemble a small TV. VGA cable is usually attached.
There are also LCD flat screens that have a VGA connector, for a VGA cable, and may also have both a VGA, and a DVI connector.
To digress for a moment;
VGA is Analog. It uses an Analog video signal.
DVI is digital. It uses a Digital video signal.
A computer naturally puts out a digital video signal. This digital signal has to be converted by the computer, into analog for an analog monitor. This slows the graphics process down. This is one reason it is best to use digital )
2) Plug a monitor with a DVI cable into the white DVI port on the graphics card.
3) Turn the monitors on.
4) Turn the Inspiron 531s on.
5) When Windows has loaded, right-click on an empty area of your desktop computer screen.
Now left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
6) You are now looking at a small window that has two monitor icons in it.
Monitor 1 icon, and monitor 2 icon.
Monitor 1 icon is your Primary Display.
Monitor 2 icon will be for the Secondary Display you are adding.
Note how monitor 1 icon is sitting to the Left, and monitor icon 2 is sitting to the Right.
This is how your monitors are supposed to be arranged on your computer desk.
If the second monitor is on the Left on your computer desk, you need to move the icons around.
Move monitor 2 icon to the Left.
Left-click on the icon, hold the left mouse key down, and drag the monitor 2 icon over to the left side of monitor 1 icon. (All the way over, or it will snap back to where it was)
It may matter to you how your monitors are arranged. It may not. Once you read the following it may help you decide.
7) Left-click on monitor icon 2 if you have not already done so.
Go down to where it states, "Extend my Windows desktop onto this monitor"
8) Left-click once in the empty square, to the left of Extend my Windows desktop onto this monitor.
9) Now left-click on Apply at the bottom Right corner.
10) Finally left-click on OK at the bottom Left corner.
You should now see your desktop screen on both monitors.
When using the internet on both monitors, you have to drag the screen from the Primary monitor to the Secondary monitor.
Go to the left side of the screen. Left-click right on the edge of the blue frame. Hold the left mouse key down after you click, and drag the screen across to the left.
Doesn't work?
Go to the right side, click on the blue frame, and drag the screen to the right.
This is why it may matter how the monitors are arranged on your computer desk.
It's kind of eerie your first time dragging the screen across.
You will also find out why it is best to use two similar monitors, when using dual monitors. The pixel resolution is different for both monitors, if they are different from each other.
For additional questions please post in a Comment.
Regards,
joecoolvette
Just to add:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
What is the square symbol next to signal icon?
Just guessing here but I would say it's your battery icon.
Guessing because I don't own an HTC.
Educated because most phones esp Androids are set out the same way.
Or it could be you have your phone on silent and its the Vibrate on Icon.
That looks like a little mobile phone with little vertical lines on either side of it.
Or you could be talking about the letter 'H' That appears if you are in an Hspa area. (faster than 3g)
Feb 24, 2011 | HTC Wildfire Cell Phone
Where is the location of the turn signal flasher?
I have a 94 Sonoma and to locate the turn signal flasher, inside, under dash, on left side is a plastic sound protector, mine had 3 screws holding it up, drop this down and straight in you will see a 1" round thing - this is the flasher.
Jan 08, 2010 | 1995 GMC Sonoma
1999 dodge intrepid can not find signal flasher -not in fuse box -can not see it under dash??
Left side of the dashboardthe driver's left leg area.....on the side of the dashboard.
Mar 04, 2009 | 1999 Dodge Intrepid
No turn signals............
If you look under the dash on the left hand side you will see the fuse area, behind this you should see a large ( about 1 - 2 inch) black square block. These usually sell for about 10 - 15 dollars each at the local auto stores. This is a link to a picture of them. Carry this into your local parts store and put in the new one and you should be good to go.
Please let me know if I can offer further assistance! I hope you found my answer helpful - if you need clarification please just ask me!
Jan 03, 2009 | 1999 Dodge Durango
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
