Question about Admiral AW22 Top Load Washer
Admiral top loader no spin cycle
Hello tech17 just finished assembling the new lid switch works like a charm.
Thank you very much for you help for solving the problem.
Great Work.
  • Mike 1954 Apr 02, 2008
    My Admiral AW22 Top Load will fill with water, sometimes (not all), will go through a cycle then stop. All of the water remains in the washer and it will not go to the next cycle. I'm stuck with a washer full of water. How do I get the water out, and how do I fix the problem?
    Any help is appreciated.
    Thanks.
  • Anonymous Mar 24, 2014
    which cycle will give a full rinse instead of a spray rinse
    President:
  • 1,314 Answers
Hey my man you did it not me but glad to assist
Posted on Mar 17, 2008
Top loader washing machine stops mid cycle and won't finish rinsing or spin cycle. Any ideas?
Check the lid closure switch. This keeps the unit from spinning if the top lid is open, as a safety interlock. The switch gets a lot of abuse, as the lid sometimes slams down and damages the switch. If the switch is damaged, the washer will stop before the final rinse, or spin, depending upon the model. This can be repaired, but takes a bit of work. I did mine myself, with great results. If you are not inclined in that direction, have it repaired. It costs far less than a new washer.
May 10, 2017 | Washing Machines
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Bought used roper washer. worked for first load and now wont work. washes and then the dial satys in same place. Wont empty or spin, nothing.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Roper RAS8445KQ Top Load Washer
RAX7244JQ0 Roper washer fills, starts to agitate but then it stops on the spin cycle and will not drain. not sure which part to replace--timer?
Hello, Thank You for using FixYa. I will be helping you today. The lid switch failed you need a new lid switch part number 3949247 this link has the part and a video how to change it http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Roper Washing Machines
Hi Guys, I have a Whirlpool stackable washer model # LCP-4332-PQ1...I ran it for one load and it was fine...I unloaded it and went to get more laundry for another load...When I left, I left it...
Hi rcdrivertim,
I believe the problem is the Lid Switch. Find it here:
http://www.appliancecarestore.net/whirlpool-amp-kenmore-genuine-washer-lid-switch-.html
If the Lid switch does not work, the machine will not switch over to cycling, thus not work.
You could always test the Lid switch by switching the attached wires to continuity, also known as bridging.
Hope this helps :-)
If this answered solved your problem, please accept it. If it did not, please comment and I will help you further.
May 02, 2011 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
The machine wont go into drain or spin cycle. also the lid switch does not work - model 6ALSR7244JQ1, serial CL4103568
HI!!
If lid switch does not work, the machine will never go into the drain or spin cycle. Replace the lid switch and you'll be fine. You can get the switch at any appliance parts store or on this site for $33.50 http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/547391?modelNumber=6ALSR7244JQ1
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 14, 2010 | Whirlpool LSR5132PQ Top Load Washer
My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Feb 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Roper washing machine is not spinning the water out. It is washing normal but when it comes time to spin it just stops. Please any info would be great. Thanks
Hello
Welcome to Fixya
My name is Huum,
Three possible reasons are:
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Defective Motor
If the motor is not running, the pump will not work. Most washing machine use a reversible motor and it is possible for the machine to agitate and not spin or drain.
Defective Water Pump
If the motor is running and water is not pumping it could be a defective water pump. Ensure the tub to pump water hose is clear. If so, replace the pump.
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Dec 15, 2008 | Roper RAS6233KQ Top Load Washer
Just wanted to say THANK YOU, THANK YOU!
a great reply like this is thanks enough we rarely get them but its no big deal most of us are here to help but you can post to this message and rate me after wards that helps my rating four boxes is great but thank you for your kind reply
Jun 09, 2008 | Whirlpool RBS275PD Electric Single Oven
Admiral AW22 Top Load Washer Logo
101 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
