Question about Toshiba DR4 DVD Recorder
Incorrect disc My toshiba DR4 vcr/dvd recorder always reads "incorrect disc", everytime set it on DVD,no matter what kind of disc I insert. It even reads this when activated with no disc inserted. This occured while trying to record my first DVD.I have tryed every solution posted, but nothing works.
  • red dwarf Mar 18, 2008
    Those two were the first two that I tryed. I left the unit unplugged for five days. With the "incorrect disc" problem no discs at all will play, incuding a lens cleaning disc. As I stated in my initial request for assistance, I tried every posted solution, and even a few others that I thought of, and nothing worked. The "Incorrect Disc" still flashes everytime the DVD button is pressed. I would like a solution that actually works. After further researching of this website, I read all the other complaints about this unit. I now realize that the toshiba DVR-4 has major deseign flaws. I contacted toshiba customer service and they have no clue as to a solution, nor did they seem to care. This unit cost $250.00. HELP, PLEASE!
  • red dwarf Mar 20, 2008
    The DVD-R that I used was compatible with the DVR unit, according to the manual. As I stated before, the unit will not play discs of ANY kind.As soon as you press the DVD button,the "incorrect disc" starts to flash. It also appears when opening or closing the disc tray. Hittng the "OK" button takes the "incorrect disc" off the screen, but as soon as you try the DVD it comes back on. I was told by an electronics repairman that the unit could cost up to $150.00 to fix and it's possible that it will happen again. Can anyone send me instructions so I can atempt to repair or replace the laser myself, if no one can offer a solution that works? Since the unit will NOT play ANY disc of ANY kind,I've got nothing to lose.
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
If the problem still persists then you will have to get it repaired and thats the only solution..
Goodluck..
Posted on Mar 20, 2008
  • 818 Answers
1) What disc do you use for record your dvd?
2) your problem seems your laser. if you read this
DVD-R discs recorded by DVD Video method can be played. Some DVD-R discs may be incompatible due to laser pick-up and disc design. that i found in the toshiba site.
Sergio
Posted on Mar 18, 2008
    President:
  • 1,944 Answers
Did you try using a disc cleaner to clean the lens? Did you try disconnecting the unit for a few hours to hard reset it?
Posted on Mar 17, 2008
    Brigadier General:
  • 3,614 Answers
Corporate egos got in the way. Unable to agree on one format, the consumer electronics industry spun out six recordable DVD formats: DVD-RAM, DVD-R(A), DVD-R(G), DVD-RW, and DVD+R/RW. All let you write to DVDs. Only –R and +R, at the moment, are readable by most consumer DVD players. And few experts are sure of the qualitative differences between the dash and the plus formats.
Tv flickers on dvd playback on toshiba dvd recorder
Could be the usual problem of a greasy center-disc =
95% OF THE TIMES I could fix a problem like this was by cleaning with rubbing alcohol the rubber ring on the little rotating disc in the center of the drive mechanism. !!!! Because users always stick their index finger into the hole of all the CD'S for inserting a disc into the tray that a tiny amount of grease gets deposited onto the little rotation disc which touches the center of any inserted disc at about half an inch from its center hole. (underneath) When its greasy the discs slide and the inserted discs speed stays uneven and slow.
You must open the drivebox ( after unplugging the power-cable) to see and clean it.
Be careful to not look at it with power "on" because the laser will make you go blind (danger!!!!!!!
Apr 07, 2013 | Toshiba DR4 DVD Recorder
My toshiba dr4su will no longer record on dvd-rw discs nor will it format a blank or prerecorded dvd-rw.Ihave used this recorder successfully for a couple of years. It will play back dvd-rw. When I attempt...
If its an older recorder it could be the usual problem of a greasy center-disc =
I heavily use a Toshiba DVD recorder since 12 years and it is my most reliable and most versatile recorder, while my brand new Sony recorder lasted only 2 years - Others as well had problems with finalizing etc. but in general the cleaning of the little center-disc that pushes from underneath against an inserted DVD to make it spin helps the most.
Oct 26, 2011 | Toshiba DR4 DVD Recorder
Incorrect disc
Some machines work with -R some with +R. My suggestion is to try a + or - R RW which is rewritable. If you screw it up, no harm done because you can always reformat it and start over again. Don't forget to format the rewritable at the start.
Sep 19, 2009 | Toshiba D-VR4 DVD Recorder/VCR
I am getting same Incorrect Disc error on any dvd.
plz check your optical lence (laser assembly) when it become weak then it shows like that.
solution:- remove the optical head of the dvd player & replace same one.
thanks
Sep 12, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
DMR-EH75V DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
Tuner won't go above Channel # 99?
Most cable boxes that go past 99 are digital channels and require the cable box to tune them in. You can always set the cable box to the station you want and hookup the rca output to your DR4 rca input and record from that. Their is no other work around for this because the DR4 has an analog tuner inside of it and your cable box is a digital turner.
Dec 20, 2007 | Toshiba DR4 DVD Recorder
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Auto Chapter Not Working
You might want to visit here http://www.amazon.com/Toshiba-D-R4-Multi-Drive-DVD-Recorder/dp/B0007UVYOY
Sep 13, 2007 | Toshiba DR4 DVD Recorder
Toshiba DVR recorder incorrect disk message
I find when my unit gives that same message, if I unplug it for a few hours, the memory resets itself. You may have tried this already, but it does work with my machine. tcast at yahoo.com
Jan 28, 2007 | Toshiba DR4 DVD Recorder
Toshiba DR4 DVD Recorder Logo
284 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
