Question about Radio Communications
Cb radio I have a GE handheld cb radio model no. 3-5980a and was wondering what was inside and i broke off the wires going to the battery box. I need to know where they go. (picture would help a lot thanks)
  • 47 Answers
Do you have a multimeter?
If yes
one of the wires will have 0 Ohms to ground. that the {-} wire, the other is the {+} wire
Posted on May 26, 2008
My dash cigarette lighter works, but I pluged in a handheld cb radio walkie-talkie and it burned up my batterys? what could be my problem here?
We need to know what the handheld radio make and model is and we need to know what the same info is on the charger.. There are chargers that reduce the car voltage from 12 to 9, 6 4 etc, even if it fit the jack on the radio it can put the wrong voltage in or it can have different polarity.
Nov 11, 2016 | Radio Communications
I have a Uniden UHF CB Handheld Model # UH076SX-NB. Have had it for 3 years and only used a dozen times. Now I can receive but unable to transmit. Any solutions please?
How do you know that the radio does not transmit? The batteries need to be fully charged, or new to transmit. The radio is old, and the cost to repair it may be close to how much a new CB radio is.
Good luck.
Aug 25, 2016 | Uniden Radio Communications
Cobra troubleshooting
These models have all connections going thru the mic cable. to the lil box.. if your getting supply voltage on the pins at the box.. check for a bad mic cord..
Jul 30, 2014 | Cobra 75 WX ST 40-Channels Handheld CB...
Wire broke broad
sometimes this works,take the wire holding it at the broken end , stretch it out not to tight but tight enogh to see where it would connect by moving it around the inside and looking for a wr spot thats missing a wire.If you can't find it you will have to take it to someone that knows where it goes.Contact friends and see if they can do it.other than that you will have to get it to a tech.
Apr 29, 2014 | Cobra 29 LTD CB Radio
I have a midland 75-822 micro mobile-portable cb in my van. a lot of static and i was wondering how to correct it. thank you kindly.
your problem has many fixes depending on how you use your radio, but first think of were you are transmitting from a van or car is literally a big metal box so the squelch minimum will increase a bit if your antenna is inside the van. but if you use/get the UHF-DC adapter for this radio it will alow you to mount a exturnal antenna on the outside of the van, the other possibility is a bad placement of the antenna try changing its location. however if the noise increases as you excelarate then you might need a in line DC Noise Filter.
Jan 24, 2011 | Midland 75-822 40-Channels Handheld CB...
HOW TO INSTALL BATTERIES IN MAXON 27KC AND WHAT ARE THE TWO BLACK THINGS IN WITH THE BATTERIES
KC27 Maxon CB need 10 batterys rechargables 1.2 v for 12v total, use the most amperes or miliamperes possible, if you have a charger case or 27-CRDL Cradle for 27-KC you can use 13.8v regulated 5 amps. máx. but need external antenna. When you put a radio in charger case it switch to use external mic, voltage, antenna & speaker. Actually 2500 mAh "AA" battery is very common and cheap. You can charge batterys on to radio case, only need a 200 mAh eliminator at 15v for 6 hours.
May 31, 2009 | Maxon HCB-10 40-Channels Handheld CB Radio
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Radio Communications Logo
196 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
