Question about Vacuums
I disconnected the Kirby vacuum to blow out and clean under my refrigrator, when I put it back it wont come on, don't seem to be getting any electric.
    New Friend:
  • 136 Answers
Make sure your electric plug is still in place
Posted on Mar 17, 2008
It's been awhile since I have used my shampoo system on my Ultimate G series Kirby. Well, as instructed I took it apart and cleaned it. Now I can?t figure out where to put the ?screen cap? and ?sponge...
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 15, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby heritage vacuum front light
yes there is should get a vacuum store to take a look at it.
Jun 05, 2009 | Kirby Heritage II Vacuum
Kirby sentria shampooing not right
make sure u put the exact/right instructed amount of soap in the tank.....after each room, wash & clean tank filter. open tank all the way.....pull back slowly. if too much foam...adjust tank knob.
May 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have a kirby Tradition. The belt has come of and also the bit you turn to stretch the belt. I have all the bits but no idea how to put it together
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656063
Generic problem for all Vacuums
I have a Kirby Tradition.
Posted by Pagan1 on Jun 08, 2008
I have a Kirby Tradition. The belt has come of and also the bit you turn to stretch the belt. I have all the bits but no idea how to put it together
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have never come across the entire belt hook assm has come completely apart, but I have seem other people put the assm back together, but I would bring it to a local Kirby vacuum cleaner dealer in your area and if for some reason they cannot repair the Kirby head and hook assm they can order you a compete head totally repaired, but that would be choice #2 or feel free to contact your local Kirby Vacuum Cleaner Dealer to give you a breakdown on how to put it back together again. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hour’s 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
New Kirby
Is the bag emptor all of the way on? It will blow out if it isn't, But being new, you must have a number to call, it is under warranty so they should be able to help you out.
May 25, 2008 | Kirby G5 Bagged Upright Vacuum
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542493
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Kirby blowing out aire
Unplug the vacuum and clean out the hose that goes from the beater to the intake. The hose is either plugged with debis or has become disconnected or BOTH. You may have to use a screw driver to remove the plate over the beater brush.
Mar 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby sofa cleaner
Hi, my name is Jon and I have an Ultimate G Kirby and have sold Kirby and the solution to this problem it is very simple. All you have to do is first disengage the belt by lifting the hood and twisting the plastic thing that says Kirby. Twist it all the way till the red arrows meet up then you will know that the belt is disengaged. Next you're going to disconnect the front by pushing the small metal lever/lock under the hood to the right and the front end should come right off. REMEMBER put the vacuum on the highest setting so this will be much easier to do. Then what you want to do is connect to hose and you will do so by connecting the hose in the same manner in which you would connect the front. There is a perch for the hose or any of the other attachments to rest their "feet" on as you will see the end of the hose is contoured to fit the Kirby in the same way the front end does. Lock the hose in place with the metal lever/lock by putting it over to the left. REMEMBER to disconnect the belt when you take off the front end and ALSO to reengage it when you put the front back on. I hope to have solved your problem, and I'll talk to you later!
Nov 18, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
