Washing machine filling with water while not running
We have the GHW9100LW2 and recently, the tub has begun to fill with water while the machine is not being used at all. it seems to work fine while washing, but there should be no requirement for water when the washing machine is off, right? our fear is to return home from work and find water all over the floor because it over filled when it should not be filling in the first place!
thanks,
Steve
    President:
  • Washing Mach... Master
  • 2,651 Answers
Youll need to replace the water inlet valve, its not seating properly after fill, and continues to leak into machine.part number 8181694. in hte ean time you can turn off water supply to machine inbetween wash loads.A good habit to be in anyway.
Posted on Mar 18, 2008
My Bosch washing machine pumps the water out continuously without ever filling the tub. When I first start a load, the water moves through the detergent dispenser but never gets to the tub. About 5 minutes...
Could be time to call the electrician. If the freeze happened recently you are possibly further inland than me. Lagging on pipes often helps and wrapping external taps and pipes with towels or the likes for winter and with plastic tied over top if in the weather. After super cold frosts we are best not running showers and taps till midday or later occasionally. Vehicles can be similar if it is cold enough. Fill jugs and bottles the night before for breakfast if the water might freeze. If your water might be soon dirty because of a flood or water supply stopped, fill the bath with clean water before it is
Feb 28, 2014 | Washing Machines
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 31, 2011 | Washing Machines
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
No water in tub,water supply is conected but it doesn't fill the tub
heatman101
Mar 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Neptune frontloader washed accumulates water
replace water valve if its filling while not being used. if u hear the water in the tub but noty seeing it thats normal they water in them always. as far as mold u can buy some affresh its a cleaner for the frontloads
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine won't fill up with water
Hi can you tell me the make and model of the machine and if it makes any noise when it is trying to fill?
Then we can fix it!!
Feb 15, 2009 | Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Filling With Water
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
May 06, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
