Question about Dryers
Fisher and Paykel DGGX1 Gas Dryer Not Heating
The dryer seems fine in all apsects except it does not heat. I suspect a thermcouple or thermostat, but I don't know where to look for them.
Any help would be appreciated.
Thanks!
  • 1 more comment
  • Anonymous Mar 22, 2008
    I have the same problem with my F & P gas dryer model, runs but won't heat...Any solutions?
    I have the same problem with my F & P gas dryer model runs but won't heat...
  • catfish8637 Apr 06, 2008
    fisher & paykel gas dryer modle # dggx1 not heating.
    New Friend:
IF THE BURNER DOES NOT LIGHT --
On gas models of the F&P top load dryer, there is a reset button for the gas igniter. Take the front panel off as described above and you will see some orange wires leading to the front of the burner. Remove those (one side has two orange wires, the other one - note which is which; generally the two wire connection is on the left) and the reset button is between them. Press it, replace the wires and start the dryer. The gas should light in about 15 seconds. If it does let it run for 10 minutes or so to insure it is fixed. Then shut down and replace the front panel.
IF THE BURNER LIGHTS THEN SHUTS OFF --
Check the lint trap as described above and also check the lint vent outside the house. My vent goes up through the roof and the lint builds up about every two years. You can by a vent cleaning brush off eBay for less than $20.
Posted on Aug 09, 2010
  • ombligo Aug 09, 2010
    IF it won't light at all --
    There is a reset button for the thermostat. Remove the front panel and at the bottom center-right you will see some orange wires. the button is between them.
    If it lights then turns off --
    clean the lint screen as mentioned but also check the outside lint vent on your house. Mine goes through the roof and clogs about every two years. You can get a vent cleaning brush off ebay for less than $20.
  • mlewis242 Oct 05, 2010
    Clean the lent trap (by removing the screw) and the flow increased by 100% but it still was cold, I then pushed the reset button and boom - that did it!! Worked perfectly for me thanks!!!
    New Friend:
  • 136 Answers
You can get a heating element at any junkyard for like 5 dollars
Posted on Mar 18, 2008
I had the same problem. To get a good look at the ceramic igniter, it helps to remove the three sensors from the front of the burner chamber. Upon inspection, my igniter looked fine. So I reinstalled and reconnected the sensors, and everything worked!
I suspect there was a loose electrical connection at the sensor closest to the corner of the unit. Anyway sofar so good.
Posted on Jun 17, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
If the dryer doesn't heat at all, the most common cause is that the ceramic igniter is broken. These are very fragile, and easily cracked in transit or moving around. It's located just inside the front panel on the right side. You need to remove the front panel by removing the two little plastic inserts on the top front and the screws under them.
If the dryer heats, but the clothes take forever to dry, the automatic lint scraper may not be working, and the lint screen could be clogged. Remove the lint basket (inside the drum on the left), take out the screw behind it, and remove the whole round plastic piece. You will see a lint screen all around the outside, or a big wad of lint all the way around, if it's not working. If lint, just carefully pull it out with a small screwdriver. (DON'T poke a hole through the kint screen). Hope this helps
Posted on May 17, 2008
SOURCE:
I have a 20 year old electric dryer that normally works great. All at once the dryer stopped heating, but otherwise works normally. I took the dryer apart, checked continuity of the heat coil, hi limit...
The problem is the terminal block, Vibration with the cord not being fastened to the block tight enough caused overheating at the block and it failed. Replace it.
Jul 19, 2013 | Dryers
Model #CEDX563JQ0 Crosley Dryer won't heat and getting current
I would check to be sure you have 220v going to Dryer. Possibly timer problem as heat circuit runs through that too.
Aug 27, 2017 | Crosley Dryers
My Blomberg 1330A stopped heating. Heating element seems fine, so now looking for the thermal switch...
Test the heating element with a meter for continuity with a meter.
After that follow the wires, one thermal fuse should be neer the heater element the other near the exhuast.
Jan 12, 2013 | Dryers
Hello, my dryer doesn't dry the clothes. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else? The machine works fine except that its not...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Dryers
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
We have a 5 year old Roper electric dryer that started to fail in heating the clothes. I've checked the electric plug at the wall, and have 240 volts. I've checked the thermal fuse, and the continuity is...
You can test the stats they should read short circuit/ normally closed, you could short them out for 10 secs to check not good idea to leave permanantly as would cause safety issue element if one section two wires plus an earth to it should read about 30 0dd ohms
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool YLER7647EQ0 No Heat
It sounds like your whirlpool dryer may have a problem with one of its thermostats. This is a common problem and can be tested for continuity as well. Simply unplug the dryers power. There it a Hi-limit thermostat on the elements housing, it is the LOWER thermostat. disconnect one of the leads to the thermostat and test it. if its not reading anything, then it is faulty. part number for the hi limit thermostat is 3390291. The other thermostat is located on the blower housing it is the air circulation thermostat and can be accessed through the front panel. Again perform the same check with power disconnected and you will most likely have an answer. part number for the cycling thermostat is 3387134. Hope this helps.
Thanks.
Nov 07, 2009 | Whirlpool Dryers
Kenmore dryer doesn't get hot but drum rotates fine
I read on another page
1) One of the thermostats could have a reset switch on it to cure problem... do not know where to find it or what it looks like! ....
2) May need to replace the element...
3) Could be the exhaust thermostat / or heater and thermostat complete/ check continuity...should be normally closed(complete circuit)
Any help to you ????
Best wishes willow
Mar 13, 2008 | Dryers
Dryers Logo
1,289 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
