Question about Lightning Audio FF150.2 Car Audio Amplifier
Blown fuses My FF150.2 amp just up and started blowing fuses it has been set up the same no changes why would it just start blowing fuses?
The reason could be because the energy is not well installated or your speaker wires are toucing somehow.
Posted on Mar 18, 2008
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
Blown fuse amp start fuel 8
Pls be more specific, doe's this fuse keep blowing or what? Fuse blows and your car won't start. I have a 2004 GTC and the #8 fuse kept blowing, had to replace the starter, (it was pulling 80amps instead or the normal 30-35) once the starter was replaced, no more starting issues and the fuse no longer blows. Hope this helps, good luck
Sep 12, 2012 | 2004 Chrysler Sebring
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Microwave combination oven failureHME9750GB/03 FD8106 (/555350)
APPLIANCE HAS INTERNAL 8 AMP SAFETY FUSE IF THIS HAS BLOWN IT WILL NEED MAJOR REPAIRS AND POSSIBLY COSTLY THIS FUSE ONLY BLOWS IF FAULTS EXIST WITH HIGH VOLTAGE SIDE OF APPLIANCE SO NO NOVICE SHOULD ATTEMPT A REPAIR.
Jan 18, 2010 | Bosch HME9760 Microwave Oven
2001 taurus will not start.
if that fuse always blow out then you have a short circuit in your electrical lines.
Jun 21, 2009 | 2001 Ford Taurus
Fog lights blow 15 amp fuse
i had the same problem...but mine is after i install a new set of HID kit..after a couple of weeks it just died..then i check the fuse it was blown..then i changed it and turn it on and it blows again...i did change it again ..same thing it fuse blown.
Jul 18, 2008 | Plymouth Voyager Cars & Trucks
Sony projection big screen
does the led flash when you try to power it up? If so let me know the number of flashes. From your description I would suggest 1 of 2 things happened. (1) The Convergence amp ICs have shorted and blown the 5 amp fuse on the G board, or (2) the red CRT has shorted shutting the set down. Check the fuse and if blown replace the fuse and disconnect the Red CRT PC board from the RED CRT and try powering up the set. If it powers up without shutting down then unplug the set and rehook the RED crt pc board and try again if it shuts down the reds shorted. But if it still wont start with the CRT unhooked or blows the fuse Change the Convergence ICs
Apr 06, 2008 | Sony KP-57XBR10 57" Rear Projection...
Explode Amp
Is the equiptment used? Your subs may be blown, try disconnecting them from the amp, then power it up, and then see if it still blows fuses. If it does, your subs are either wired incorrectly, or blown.
Aug 05, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Lightning Audio FF150.2 Car Audio Amplifier Logo
102 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
