Question about Hoover Washing Machines
Water Accumulating in Washing Machine Drum
Newly installed Hoover washing machine. 1600AAA. Clear water is accumulating in drum when not in use. Seems to empty end of cycle or when use spin to empty but then fills up again? Outlet pipe is to sink drain and as close to 800mmas possible at highest?
Whats the problem?
    Top Expert:
  • Hoover Master
  • 30,501 Answers
Could be draining from your sink outlet. Ensure the outlet pipe is routed higher than the sink trap. Normally attached underside of the work surface.
Posted on Mar 04, 2018
SOURCE:
  • 38 Answers
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Posted on Mar 05, 2008
ginko
  • 19396 Answers
SOURCE: hoover visionHD 8 kg 1400 spin
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
Posted on Oct 16, 2008
  • 135 Answers
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Posted on Nov 15, 2008
  • 127 Answers
SOURCE: Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
  • 215 Answers
SOURCE: How do I install a second hand waher/dryer with limited piping?
1 yes all standard.2 Yes you can get a Y piece. 3 no you will only use water from cold. But you can solve that by going to a good hardware store or B.Q and gettein a self cutting tap for washing machines. You can fit this in just minutes, and do not even need to turn off the water supply. just make sure there is a clean straight piece of pipe to fit it to. 4 yes fit waste pipe to u bend under sink.
Posted on Feb 08, 2010
Tip
Hoover 1600aaa
Just a basic one before you phone your washing machine engineer on the hoover the pump does seem to clog up very easily basic problems to which you wouldnt even guess what the problem can be.Your pump maybe blocked hair bobbles,money even pet hair can cause this.
problems:
machine wont drain or spin
the best way to fix this is too always pull down the front flap underneath the drum
Makesure you ave a tray to accomadate all the water in there if it is blocked there will be a lot anything that could be blocking it will be there.
Once any blockage is removed put the plug back in and test to see if the wash will work if it does problem solved and you just saved yourself £50 plus
on Feb 27, 2010 | Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Mar 08, 2009 | GE S8000E
Water not draing away and machine is not spinning
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Washing Machines Logo
186 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
