Error on printer
I have a clx 3160FN it is saying "Transfer belt error" and "scanner lock"
  • gm08 Jul 17, 2008
    We have a Samsung CLX 3160FN ...we first had to replace the imaging unit and then later the transfer belt. After replacing the transfer belt, the copier would not recognize that the part had been replaced. It still states that the transfer belt needs to be replaced. We have taken it back to Office Max and they could not help us, we have talked to numerous people at Samsung customer service and they were not helpful.
    Any suggestions on what needs to be done?
    Scholar:
  • 104 Answers
There is a safety lock on the scanner that may be in the locked position. Turn the unit off and locate the green lock lever/switch under the scanner where the paper comes out. It will be labeled with a icon (picture) of a lock (unlocked and locked). Move it to the unlocked and locked position multiple times, ending up in the unlocked position. It may be stuck so moving it back and forth may release it. Turn it back on and try it.
Posted on Mar 17, 2008
SOURCE:
What is this error? transfer belt error? what is the likely repair cost?
It means that the transfer belt count is at the limits of its useful life. The part number is JC96-03611C. The typical replacement part cost is around $150- $200.
Feb 02, 2011 | Samsung CLX 3160fn All-In-One Printer
The printer will not print I receive an error message
undr the scanner the is a lock.Unlock it...it looks like a switch.The scanner does not righ the home position
May 29, 2010 | Samsung CLX 3160fn All-In-One Printer
Transfer belt error samsung CLX-2160 help
The first thing to try is to turn the printer off, unplug it from the wall, then plug it back in and turn it on. If the error message goes away, you can resume normal operation. If the error message still appears, you'll have to call your service technician.
Feb 09, 2010 | Samsung CLX 3160fn All-In-One Printer
Error message "scanner locked" on clx-3160fn
common problem with these printers,need to replace flatbed scanner.this is where you copy and send documents.
Jul 15, 2009 | Samsung CLX 3160fn All-In-One Printer
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Transfer belt error
Rather than turn printer off, unplug from power source, wait a few minutes and plug back in. It's worked twice for me so far...
Sep 12, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Transfer belt error on Samsung 3160Fn
Yes, I fixed the problem. Send me $19.95 and I will tell you.
May 24, 2008 | Samsung CLX 3160fn All-In-One Printer
CLX - 3160FN
Look under the flatbed (do not take anything apart) just look where the paper comes out when you print...you will see a green switch on the left, push or pull it, this is the scanner lock...I am guessing it is for transportation purposes...I had the same problem and this was the fix...Good luck
Apr 08, 2008 | Samsung CLX 3160fn All-In-One Printer
Transfer belt error
Transfer belt error, this is cause by the OPC drum which connects the belt. Make sure the drum sit well with the belt else replaced the drum.
Jan 29, 2008 | Samsung CLX 3160fn All-In-One Printer
1,157 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
